Question about tire size... LS430 rims on 1998 LS400 *with pics*
Old 02-29-12, 12:47 PM
rishi
rishi's Avatar
Default Question about tire size... LS430 rims on 1998 LS400 *with pics*
okay, so i got some LS430 wheels about 8 months ago.... didnt want to put them on just yet cuase the tires on my current 16in wheels were brand new MKV4.... wanted to wear them out a bit first.
so it looks like its that time to look to change them now, and i wanted to know what tire size should i use to put on the 17in 2002 LS430 wheels... i wanted to use some tires that will fill the gap up a bit that the current wheels have on the car.
What size do you guys recommend that will make it look a lot better and also handle good.
Thanks...
This is for 2002 LS430 17in silver wheels going on a 1998 LS400 with current 16in wheels.
Main reason im asking is becuase i saw someone that had a 98-00 and they put the LS430 wheels with the factory size tires, and with that combo it looked funny cause the tires were too small and it looked awkward. Def looked like the rims didn't belong. Im thinking the series should be bigger so it fills in the gap better.
My LS400 is totally factory. BTW this is the same car from the project late last year. Some additions have been, brand new shocks all around and the wood wheel.
I plan on redoing the emblems all chrome (the new LS430 wheels has chrome emblems on the wheels) and also a new grill with chrome emblem.
Attached Thumbnails Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-1-1-.jpg   Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-2-1-.jpg   Question about tire size... LS430 rims on 1998 LS400 *with pics*-ls430.jpg
Old 02-29-12, 01:10 PM
McPierson
McPierson's Avatar
My opinion is that if you want to fill the gap you really need to lower it, here's why.
Just putting on bigger wheels with the same OD tires as OEM will make the car sit taller (there is less sidewall flex).
If you then put on bigger tires it will sit even taller.
For the record I went with slightly bigger OD tires on my 18s 255/45/18, but I'm on Tanabes (no rubbing).
I suggest you just use the OEM LS430 size even though that's not what you asked.
Old 02-29-12, 01:37 PM
rishi
rishi's Avatar
well im not really wanting to lower the car... but i totally see your saying now...
Actually quite surprised i didn't put those two together prior to posting on fourm... just thought maybe there was a tire size that is better for the LS400 with the LS430 17in wheels.
any other thoughts anyone?
Old 02-29-12, 01:39 PM
rishi
rishi's Avatar
the factory size tire for the 17in wheels for the LS430 are 225/55/17
is there a more recommended tire size for the same wheels on a LS400?
Old 02-29-12, 01:40 PM
VanCityLS4
VanCityLS4's Avatar
There was a thread on this not to long ago.
Old 02-29-12, 02:12 PM
rishi
rishi's Avatar
link? i searched.
Old 02-29-12, 05:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the sidewall flex makes only a negligible difference in overall diameter for a radial tire when properly inflated. OP the LS430 and the '93+ LS400 run identical tire sizing, so running stock LS430 17 and 18" sizing (if at stock height) is not a problem and looks, well, stock.
Old 02-29-12, 06:11 PM
RA40
Super Moderator
RA40's Avatar
As mentioned, the stock diameter will be the proper size. If you want a bit more width a 245/50-17 will give you a near identical diameter. You will have the same gap from tire to fender unless you go larger or smaller diameter tires then you will have more noticeable speedometer errors.
Old 03-13-12, 10:23 PM
rishi
rishi's Avatar
okay so i go them on... i went with the originall 225/55/17 tire size, bought 4 new Michelins MXV4...
hers how they look....
what do ya'll think? opinions?
Old 03-13-12, 10:25 PM
rishi
rishi's Avatar
heres pics...
Old 03-13-12, 10:33 PM
rishi
rishi's Avatar
i think it looks better than the 16s that were on the car... thoughts?
Attached Thumbnails Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-1.jpg   Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-2.jpg   Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-3.jpg   Question about tire size... LS430 rims on 1998 LS400 *with pics*-photo-4.jpg
Old 03-14-12, 01:14 AM
RA40
Super Moderator
RA40's Avatar
Looks good.
Now a 2" drop and some 15mm spacers in the rear...
Old 03-14-12, 04:49 AM
rishi
rishi's Avatar
Originally Posted by RA40
Looks good.
hey spacers in the rear might be a good idea... which spacers should i use?? will i have to change the studs if i do a15mm? maybe 10mm?
what do you suggest? and which ones... never really used spacers personally myself.
Thanks!
Old 03-14-12, 05:25 PM
Kansas
Kansas's Avatar
Thanks!
What do you want your car to be? A comfortable daily driver or a "lumber wagon" with a drop? Do you like dodging potholes? And forget the spacers. Leave well enough alone for now and drive you car a few thousand miles to see how much you enjoy the slightly better handling (and higher tire wear) that 17" wheels provide.
I was never a fan of the standard 98-00 LS400 16" wheels or the similar dull finish 97 LS400 Coach Edition 16" wheels. I have to say that those 17" inch LS430 wheels look particularly good on your silver LS400.
Forget about eliminating that "gap" in the wheel arch and leave that for the "ricers".
Old 03-14-12, 06:09 PM
RA40
Super Moderator
RA40's Avatar
+1 Drive it as it as and see how you like.
Wheel fitment is a subject that comes with all the other mods. If you want a basic transport car don't start messing with it. Invariably it is one trade-off for another.
If you do decide go down that path, 10-15mm is conservative for the rears and would match with the fronts. Up to you.
Quick Reply: Question about tire size... LS430 rims on 1998 LS400 *with pics*
