RPM Sensor
Old 02-19-12, 02:16 PM
jcooper2
jcooper2's Avatar
Default RPM Sensor
93 LS400 Check engine Light is on, car idles fine but when reaved up to a high RPM it gets a little rough, OBD2 gives an RPM Sensor Code. Should I change the sensor and if so where do I find it?
Any help would be greatly appreciated.
Jesse
Old 02-19-12, 03:51 PM
mikes7ke
mikes7ke's Avatar
OBD2? 93? I'm a little confused.
Old 02-20-12, 02:38 PM
jcooper2
jcooper2's Avatar
Yes sir, its the code reader which I used ( Innova OBD2 Reader) it does work on the 93.
Old 02-20-12, 03:15 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
great, your code reader is reading an OBDI code (no OBDII on the LS til 95 (full compat in '96)). just get a paper clip and do the lexls.com code reading method to get a NUMBER for your CEL.
Old 02-21-12, 10:17 AM
bauceLS400
bauceLS400's Avatar
My 91 had the same problem. There was a code reading for the rpm speed sensor. The driver side Rpm speed sensor was cut by one of the pulley belts. there are two rpm speed sensors and they are connected to the distributor. I went to the junkyard and replaced mines yesterday. the check engine turned right off.
http://www.lexls.com/tutorials/ignit...tor_rotor.html
its connected to the silver bracket that goes under the distributor rotor. Best of luck.
Old 02-22-12, 12:26 PM
jcooper2
jcooper2's Avatar
Thanks for that info, very much appreciated.
vanguy
RX - 1st Gen (1999-2003)
07-29-09 09:41 AM
bodydrager
Performance & Maintenance
04-11-09 08:50 AM
Sup2jzgte
04-05-09 06:20 AM
esucaris1
07-23-07 10:03 PM
squeekyM
09-26-06 07:36 AM
Quick Reply: RPM Sensor
