Antenna for '94 LS400
Old 02-09-12, 10:41 AM
awdandrwd
awdandrwd's Avatar
Default Antenna for '94 LS400
Hello,
Now that the car is fairly sorted-out, I need to make it look less ugly. Painting the quarter-panel that got hit in a hit-and-run will help.
My car came with this ugly plastic antenna thing, I need to replace it with something less cheesy. What are my options that look decent? I suppose tracking down an OEM one is one way to go, any other ideas?
Thank you much,
Stan
Old 02-09-12, 11:54 AM
billydpowe
billydpowe's Avatar
should be able to get a used one, here in Texas craigslist has several cars being parted out, plus the salvage yards... as long as the motor works, the antenna is a quickie install and cheap..
Old 02-09-12, 12:56 PM
awdandrwd
awdandrwd's Avatar
I suspect the OEM one was replaced because the motor didn't work. Where is the motor located?
Thank you,
Stan
Old 02-09-12, 01:24 PM
billydpowe
billydpowe's Avatar
directly under the antenna, behind the trim panel, easy as pie..
Old 02-09-12, 01:54 PM
BobN54
BobN54's Avatar
I would go for a JY factory unit. If you find one with a broken mast, you can buy it cheap and then order a new mast assembly from Lexus for ~$70 - then you'll have essentially a new antenna.
Old 02-09-12, 03:45 PM
FireEMT978
FireEMT978's Avatar
I just posted one for sale on that auction site that I had bought, then found out I didn't need. I never installed it. Just re-listed it as I had found it. P.M. me if interested
Old 02-09-12, 04:04 PM
billydpowe
billydpowe's Avatar
you can buy a new mast for 15$..... save that 55$
Old 02-09-12, 04:06 PM
timmy0tool
timmy0tool's Avatar
what i would do is utilize the antenna printed on the rear glass, assuming your car came prewired for an in-car cell phone. if you have a cheap plastic antenna, you will not have the motor/mast from the factory. like everyone said, finding one at the junkyard is the way to go. even if the mast is broken, a new mast can be had online for $15 or so.
Old 02-09-12, 04:25 PM
Dubbayoo
Dubbayoo's Avatar
Dang, I wish I had thought of that before ordering one.
Old 02-09-12, 04:36 PM
tenchu
tenchu's Avatar
Please tell me how! I want to get my LS painted this summer, and it would be great if I could just have the antenna and its hole removed all together!
Old 02-09-12, 04:49 PM
denverdog
denverdog's Avatar
is it really feasible to use the phone antenna? has anyone done this? i live in an urban area, so i don't need to have the greatest possible range.
Old 02-09-12, 05:14 PM
awdandrwd
awdandrwd's Avatar
I'm into the idea of using the printed antenna. My car did come equipped with a car phone.
Thank you for all the suggestions.
Stan
Old 02-09-12, 06:22 PM
FireEMT978
FireEMT978's Avatar
Just a fair warning, I bought the FLEABAY special "OEM" mast for like $15, and it literally broke during the first retraction. It pulled the cable/gear right out of the tip of the mast. If you research the feedback on Fleabay, you will see that this happens to pretty much every one of them. IF you buy a replacement mast, ONLY buy an actual Lexus one, from a Lexus dealer, whether online or brick and morter.
Old 02-09-12, 06:28 PM
awdandrwd
awdandrwd's Avatar
I took a quick peek near the rear window and see what looks to be a mail connector under the head liner. I'll take a better look when I have some time. It there is an antenna plug there, it shouldn't be too difficult to utilize.
Stan
Old 02-10-12, 02:40 PM
BobN54
BobN54's Avatar
Yes, but not the same quality. Some have reported success with the cheap aftermarket replacement masts, others not so much. The Lexus mast is $55 more for a sure fire long term fix. No right or wrong choice, just a matter of one's priorities.
Quick Reply: Antenna for '94 LS400
