Coil pack? rough start, smoke
Old 01-29-12, 01:43 PM
deanbrown
deanbrown's Avatar
Default Coil pack? rough start, smoke
Greetings,
99 LS, 87K
Started the LS yesterday and the engine felt like it was shaking as if running on 4 cylinders; it went away after a few seconds. Today same thing, so I turned it off and restarted it - resulting in just cranking for several seconds, no start. Tried again and it finally started, but piles of smoke out the back (just like a seafoam start). It cleared up after a few seconds and was running fine after that.
Is this a bad coil pack? Distributor? Definitely felt like a whole bank of cylinders. No engine light.
Many thanks for any advice
Old 01-29-12, 05:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
no coil pack in the '98+ cars, had COP ignition.
sounds like cam/crank sensor issue. any CEL?? I would surprised if there wasnt at least a pending code.
did you ever have the timing belt work done?
Old 01-29-12, 05:09 PM
randal
randal's Avatar
Yeah, no coil pack or distributor or high voltage wires in a 99 LS.
So, what color is this smoke? White, black or grey?
Old 01-29-12, 08:49 PM
deanbrown
deanbrown's Avatar
No engine codes at the moment, I just checked.
Smoke was light gray.
Old 02-01-12, 08:05 PM
LScowboyLS
LScowboyLS's Avatar
there is a coil pack on a '99 LS!......... 8 of them, to be exact!
Rocky317
23
04-06-19 05:21 PM
Prodigy249
11-24-16 06:45 AM
bradland
16
05-31-16 03:07 PM
CMinner
15
12-14-12 10:55 AM
1996LS
14
05-07-10 04:41 PM
Quick Reply: Coil pack? rough start, smoke
