Flashers dont work!! need help!!!
Old 01-26-12, 06:02 AM
rome99LS
rome99LS's Avatar
Default Flashers dont work!! need help!!!
Wats up guys, on my 99 after I replaced the altenator my flashers only work on the inside of the car. I checked all fuses inside the car and under the hood.
I'm thinking maybe the flasher relay!! Help plz and thank you in advance.
Old 01-27-12, 05:54 AM
rome99LS
rome99LS's Avatar
I know somebody knows, northern of my turn signals work on the outside of my car but on the inside the flash and flash fast too. Wat could it be?
Old 01-27-12, 07:42 AM
Lavrishevo
Lavrishevo's Avatar
Did you double check your wiring and grounds?
Old 01-27-12, 09:58 PM
rome99LS
rome99LS's Avatar
Naw, didn't think of that becuz, they where working fine before I did the alternator. So I kno wat i wanna check next, I just don't know where the relays are especially the flasher relay.
Old 01-28-12, 04:35 AM
billydpowe
billydpowe's Avatar
you can download the service manual here
Mod Edit: Sorry we can't allow links to copyrighted material
hope this helps..
Old 01-30-12, 04:03 PM
rome99LS
rome99LS's Avatar
Anybody knows where the relay for the turn signals are so I can do some testing??
Bump, anybody know this question?
Old 01-30-12, 04:08 PM
rome99LS
rome99LS's Avatar
No I didn't.
Old 02-01-12, 06:54 PM
rome99LS
rome99LS's Avatar
Can anybody answer my last question??
Old 02-03-12, 09:02 PM
rome99LS
rome99LS's Avatar
I guess don't nobody know where the relays for the turn signals are, cause I'm really not trying to get hammered from behind or any tickets.
Old 02-04-12, 10:31 AM
Lavrishevo
Lavrishevo's Avatar
Why don't you stop by a Lexus dealer and talk with a service advisor. If your nice and ask for help I have found they will be glad to give you advice. You could even call some dealers and explain the problem in detail and see what they say.
Old 02-04-12, 07:35 PM
rome99LS
rome99LS's Avatar
I did that actually last weekend and they said to check ur bulb. But I'm kinda confused cuz usually my dash would tell me that a bulb is out. But if more than 1 bulb is blown, then would the dash still tell me that I have multiple bulbs out??
Old 02-04-12, 09:17 PM
akitomk3
akitomk3's Avatar
Check fuses? Wouldn't hurt to check the actual bulbs. And not working you mean front and rear?
Old 02-05-12, 12:19 AM
rome99LS
rome99LS's Avatar
Yea front and rear...and I did check the fuses. They were fine. I'll check bulbs sometime tomorrow. Any other ideas while I'm into it.
Old 02-05-12, 01:05 PM
steve2006
steve2006's Avatar
If the dash warning light is working but flashing very quickly it suggests that there is no load on the flasher unit (which seems to be OK because you have the dash light flashing) so you either have all 4 bulbs blown or a wiring problem to them all.
Do your hazard warning lights work? If not I would be looking at the switch.
Looked up the manual and there is a HAZ fuse in the engine compartment supplying the Hazard Warning Lights, there is a fuse (TURN) in the interior fuse panel under the driver's side dash and the flasher unit is also on the far left of the driver's side kick panel.
Old 02-05-12, 03:12 PM
rome99LS
rome99LS's Avatar
Problem is now solved, I checked all my bulbs today and they where all blown, so i went to Autozone and got some new bulbs, and everything is working now!! Finally!!!
Thank you for all that helped!!! Now I can watch the Superbowl!!
Quick Reply: Flashers dont work!! need help!!!
