Engine wire questions
Old 01-25-12, 08:39 PM
kikcaffine
kikcaffine's Avatar
Default Engine wire questions
I just got a 93 ls400 tonight, Its been running like garbage since getting it. Has a CEL, Trac off and trac light lit up. My concern though is with some wire I found cut/not plugged in. On the driver side almost under the radiator hose from the block there is a red wire and green wire that have been cut, and on the underside of the timing belt gear there is a red wire and yellow wire not connected to anything. They look to have been in a connector but were unpinned it appears. I can get pictures tomorrow of it tomorrow. The exhaust note isnt smooth but sounds like it has a miss almost. Below 1000 rpm the car runs pretty bad, about 1600rpm it clears up and starts running better. Almost have to floor it though to get the car to accelerate or downshift. Im going to bring it to the dealer tomorrow to figure out what exactly the cel's mean. IDK if it makes a difference but the car has coilovers on it.
Old 01-25-12, 09:13 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
www.lexls.com
you don't need to take it to a dealer for the CEL, you just need a paperclip.
Old 01-26-12, 05:22 AM
kikcaffine
kikcaffine's Avatar
Originally Posted by PureDrifter
www.lexls.com
...sweet baby jesus.
Old 01-26-12, 05:29 AM
kikcaffine
kikcaffine's Avatar
What are the sensors those connectors go to? Thats whats cut on mine.
Old 01-26-12, 05:31 AM
PureDrifter
BahHumBug
you said "that" then put up a picture with 3 arrows pointing to different things....
pronoun antecedent...
Old 01-26-12, 05:32 AM
python
python's Avatar
cam sensors?
Old 01-26-12, 05:54 AM
kikcaffine
kikcaffine's Avatar
only 2 are sensors, 1 is a water pipe.
Old 01-26-12, 09:03 AM
bauceLS400
bauceLS400's Avatar
One of my Cam sensor wires was cut by the belt. i think it was the LH one. Im in need to replace mines soon. The check engine light is on but it runs like normal. weird.
biosurfer1
05-24-19 01:38 PM
LexBrett
05-19-15 12:02 PM
arcteryx
01-14-15 07:52 AM
sonyman
Performance & Maintenance
10-17-05 05:17 PM
1993ES300x
23
05-01-05 09:56 AM
Quick Reply: Engine wire questions
