Front Door Leak 99'
Front Door Leak 99'
I noticed a little bit of water running down the speaker grill on the passenger side front door today. The water is running along the door panel between the lower section of the panel and the upper section (just below the switch pod). Then it drips down the speaker grill.
It seems to originate near the front of the panel.
Has anyone had this problem? I'm not sure if it's comming somehow from behind the panel or from the front where that seam, which connects the upper and lower panel, intersects with the weather seal.
Any thoughts would be appreciated. I'm going to start by cleaning the rubber seal and the door jam where it seats.
TIA,
M@
TIA,
M@
