Supra TT brake on 1st Gen LS400
First of all,the hole in the center of the rotor is 2mm smaller on your car versus the TT,no problem, just need to chuck the part up in a lathe and cut away .080 from the center bore(.040 a side).
The larger TT calipers will hit nearly all stock wheel's spokes.
As far as the caliper mounting goes,I have no idea,but I'm working quietly on a way to have bigger brakes on a car without being affected by the wheel center design;a custom steel bracket that moves the stock (SC in my case)caliper out on the radian,or towards the edge of a new,larger TT rotor.The distance needed to move out is around .600".
We'll call it "John's brakes",when I fry my stock rotors,and get around to doing it that is,or if you want to go for it;you'll be needing something soon,from what it sounds.
David, any decent brakes are going to require larger wheels. One option is the 95+ LS400 brakes. Nearly identical to the Supra TT except 12.4" vs 12.7" on Supra. Calipers look to be identical with 4 piston calipers. You can probably get a deal from a wrecking yard or someone parting out a car. Good luck. I am following your turbo upgrade closely. Keep up the information. Maybe start a new thread so it is less massive and reference the older thread as necessary.
S2dannyKeo
Suspension and Brakes
08-20-12 01:42 PM
