Trying to Change the Look of My UCF10
So I've been over the wheel fitment thread a few times now, but I'm still not sure about some stuff.
I'm trying to go for a more sporty style with my car, I want 20's but they only look good on a few 10's i've seen around here. I would like to get a slightly aggressive stance with poke but I'm not sure how.
The car as it is now.^ The 18's are 245/40 and the wheel gap annoys me.
I really like the wheels Drifter has but I haven't seen many that are similar!
thoughts on these please. http://www.ebay.com/itm/230721083434...84.m1438.l2649
Over 70 views and no help...
If anybody could just tell me what offsets and such to look for to get a slightly more aggressive styling I would appreciate it! For both 18's and 20's btw.
Thx
Thx
Super Moderator
Those 18's are nicer looking. For stance, the Megans or the other adjustable suspensions available. I'm not familiar with the offsets for the 1-LS but at least you don't have caliper clearance issues. My wild shot for 18x8" would be somewhere around +30mm and +25mm in rear conservative. For poke with light fender mods, +20 to +25.
No one is going to go digging around the internet and/or doing physical measurements just because they see your thread/request. I'm sure if any of those people knew the information that you were looking for they wouldn't have hesitated to post it.
IMO there really isn't any way to get a more "aggressive" look without lowering the car in some way, be it coilovers or springs and shocks.
But here's something that should help you tons with your hunt for perfect fitment; http://www.rimsntires.com/specs.jsp
Sadly this application doesn't accommodate for stretched tires so you'll have to do that yourself. Reference your wheel and tire assembly you have on your car now, (diameter, width, offset, and tire size) and plug that info in one box, and then start experimenting with the other, next thing you know you'll be ordering custom wheels for mad fitment!
The reason I'm trying to avoid body modification is because its virtually unheard of where I live.
No one knows much about doing it or how to do it properly for that matter.
Super Moderator
The fitment on your current set is ok. To get the look improved you'll want to give it a lower ride height. With those current wheels and no gap, I can make a good guess that it will rub if it begins to tuck tire. If you leave a finger gap not as big a deal. What is it you want your car to resemble? Plenty of pics in the stickied threads, show us an example of what you like and we can advise.
Those 18's are conservative and unless you want stretch, you'll have sufficient rubber/sidewall to not worry about kinking a rim with most road imperfections.
BahHumBug
you can't really say you want a "slightly aggressive stance with poke" then say you don't want to stretch tires or modify the fenders. it's kind of like saying you want a real steak but it has to be vegetarian.
also, you would need to get a new suspension setup to drop the car down and get rid of the wheel gap. putting 20s on the car won't fix that as the overall diameter of the tires would need to be similar to stock, preserving the wheel gap to pretty much what it is now.
Welp I see now that to get the look I desire would require a drop, I thought I could do it with just wheels of a certain fitment! My mistake. I'm probably gonna just get these:
http://cgi.ebay.com/ws/eBayISAPI.dll...=p5197.c0.m619 And call it a day for now. Although I'll invest in some Tanabes this summer.
And somebody please tell me that hideous fendor trim on my car didn't come stock, I think its corny looking.
Edit: I am working to improve this car and all of your input is appreciated!
Edit: In so many words stuff gets old to me quick and I'm always looking for change.
BahHumBug
it is cheap. the list price on the OEM 16" wheels for my '99 was ~$600ish/each, so that alone is ~$2400 for a set.
www.vrwheels.com and memoryfab in norcal or one of the dozen other used wheel resellers probably has a solid set of used name brand wheels that you could pick up for less than that ebay crap.
