Who's your daddy?... 14.57 @ 97.29mph
#31
Thanks for the help jbrady! I know that the current setup was not optimum due to the higher intake temps, but I haven't had alot of time to fab something up. I may do so if the car doesn't sell soon. I would like to get a newer LS and a few more horses. The cone did make the car sound beeter at WOT, and can only wonder what the real gains are since I won't dyno or go back to stock at the track. I will post what I run if I make some passes in the next few weeks. I have 2 events coming up in the next few weeks. Thanks again!!
#32
Also, it is nice to see you kept the above mentioned factory air duct over the radiator. This is part of the engine compartment seal and maximizes radiator efficiency. This is another problem with most cone converstions, people take off this part. Heck, as you noticed it directs cold air right at the filter area... KEEP IT (to anyone thinking otherwise )
#33
Re: DrRick
Originally posted by LXTASY
Austin's here and waiting for another Lexus !! Hurry on down to God's country
#34
Here is the scan. The articel was a Short take. One page only. Top half is what I scanned in the bottom half of the page was just Pics of the GS.
If for some reason this is not readable just let me know and I'll email it to you.
#35
Thanks Jerry, actually the MT website has that same story but without graphics or performance data. The 103.2 would suggest actual test data vs. estimation and when estimating they will generally * the numbers and say it is an estimate.
On these short tests I would be surprised if they actually took the car to the drag strip. More likely used a 3rd wheel or even a vericom or GTech type device. At the dragstrip MPH is the average speed over the last 60 feet or so. This means actual MPH is slightly higher than recorded MPH. Using another means would not do this and show slightly higher numbers. Never-the-less this is good stuff. Let the mods continue and the times fall...
#37
Ok, if you get the chance, I would love to see a complete test of a 1998-2000 LS400 complete with engine specs, gearing, performance, weight, brakes, available options, the whole enchilada...
I would also like to know if Limited Slip Differentials were ever an option on any SC???
If you locate the LS400 test, please start a new thread for it.
Thanks
Thanks
12-21-03 03:41 AM
