Bigger rotors for LS400 Calipers?
BahHumBug
will not fit, and wouldn't help much if they did. the LS400 calipers use every bit of the rotor up so unless you had new brackets made/engineered to change the position of the caliper so that it's spaced properly, it wouldn't be worth it.
you have a jza80 supra? if so then the '95-00 LS400 calipers will bolt on but you may have a rotor bore issue (i hear they aren't the standard 60.1mm?) and may possibly have tie-rod interference. if so, DO NOT GRIND THE CALIPER.
jwynn
05-17-16 02:34 PM
indypwr
Suspension and Brakes
25
07-11-04 01:04 AM
