ucf10 & ucf21 brake booster & master pump compatibility
Old 11-28-11, 02:45 AM
Jasvin
Jasvin's Avatar
Default ucf10 & ucf21 brake booster & master pump compatibility
hi,i was wondering if anyone could help me out with this.Is the master pump and brake booster or servo assembly from a ucf21 ls400 compatible with the earlier ucf10/11 ls400?
Old 11-28-11, 09:11 AM
JimsGX
JimsGX's Avatar
You can go to Sewellparts.com and look up the part numbers for each. If they're different, I wouldn't chance it considering they're brake components... I doubt they're the same.
Old 11-28-11, 11:28 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
very unlikely.
Old 11-28-11, 03:13 PM
Jasvin
Jasvin's Avatar
they look the same in the parts pics in sewell.the only diff being the master cylinder of the ucf21 bolting on the booster using 2 screws whereas the ucf10/11 using a 3 screw master cylinder bolt pattern.the rear looks the same.i cant seem to check the brake booster part number for the ucf10/11.i dont think its available or mayb they're actually interchangeable.can anyone confirm this?
I have already upgraded my ucf10 ls400 discs and caliper to that from the ucf20/21 if this helps at all.mine was on the stock single of twin pot set up previously.
much appreciated.thanks
Hectorm
ES - 5th Gen (2007-2012)
02-10-18 08:57 AM
SorrGwa
Suspension and Brakes
39
05-08-17 04:00 AM
az90ls400
07-07-14 12:38 PM
hksnlper
12
12-04-11 08:55 PM
moviepilot
Maintenance
07-25-11 09:29 AM
Quick Reply: ucf10 & ucf21 brake booster & master pump compatibility
