1991 LS400 Starter pics and more
Old 11-08-11, 07:20 AM
fisher9720
fisher9720's Avatar
Default 1991 LS400 Starter pics and more
On my 1991 LS400, the last time the timing belt was replaces as at 73,000 miles. It now has 196K. My Fan bracket seized up, so time to do the Timing belt, also hearing a bearing whine from the front of the motor that can only be the idler bearings on the TB...
In the process of replacing the TB, also the last few months my starter turns over a little slow, sometimes it starts normally, other times slow crank condition. Starter pulling around 250 amps, somtimes less around 170, sometimes over 250, worn out... Midas well replace the starter while we're in there.
The Timing belt Idler, not the tensioner was trashed, when you turn it with your hands even at slow speeds it growls and is loose...So people always as, how many miles should I let my GEN 1 LS400 timing belt go? There 's your answer. My TB itself had small cracks on the outside, but the belt was in pretty good condition on the meat/groove side considering 120K plus miles the belt would/could go lots longer, but the problem is the idlers especially the non-tensioner idler which is really worn out. one more clue, when cold the idler bearing noise was louder, after the vehicle warmed up to normal operating temp, it would quiet down, another clue it's bearing related!
Here are some pics, had the starter rebuilt and reinstalled, had to take off intake, rear by-pass joint, or crossover tube, and the EGR intake Tube that attaches to intake Manifold. New gaskets for intake, and crossover tube, I went ahead and replaced the valve covers while there also, they were original, seeping a little bit, not too bad for 20 years!
Also I don't think my radiator has ever been out, check out the dirt and leaves that was caked on the radiator. Wonder if the previous TB replacement, they left the radiator in. Kind of weird, because I definitely don't drive on dirt or gravel roads, keep the car rockstar clean. Noticed the AC the last few years in the dead of summer isn't cooling as good as it used to, this is the reason why!..LOL..It's a wonder the condenser ever cooled down at all with all this crud in there blocking airflow.
Thought you guys would enjoy pics, we see lots of threads about starters and how hard they are to replace, but you rarely find pics, so here you go!
Attached Thumbnails 1991 LS400 Starter pics and more-starter.jpg   1991 LS400 Starter pics and more-radiator.jpg   1991 LS400 Starter pics and more-motor.jpg
Old 11-08-11, 07:58 AM
python
python's Avatar
replace the knock sensors and connectors while ur in there
Old 11-08-11, 08:30 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
and may as well do dist. cap and rotors too
Old 11-08-11, 10:22 AM
FrankReynoldsCPA
FrankReynoldsCPA's Avatar
Question:
Why the HELL did Toyota put the starter there?
I miss the good old days when starters were located in convenient locations. I can change a starter in our truck in 5 minutes.
Old 11-08-11, 01:18 PM
timmy0tool
timmy0tool's Avatar
Originally Posted by BrettJacks
Question:
agreed! i was looking for the starter and never knew it was UNDER the intake mani! i hope i don't have to replace that anytime soon.
fastegg
16
08-25-16 09:12 AM
Neil4Speed
Performance & Maintenance
11-03-11 01:37 PM
Scott1258
05-15-11 02:41 PM
TheRonTom3
21
08-30-08 02:02 PM
emacblane
09-20-06 10:58 AM
Quick Reply: 1991 LS400 Starter pics and more
