91 ls400 replacing both inner and outter tie rods
Old 10-27-11, 07:30 AM
paulwall86
paulwall86's Avatar
Default 91 ls400 replacing both inner and outter tie rods
Im replacing the inner and outter tie rods. I just wanted to know if there is anything else I can replace while im doing this that won't be too bad and costly to replace?
Thanks
Old 10-27-11, 08:27 AM
midwest2
midwest2's Avatar
Thanks
May as well do the lower ball joint since you will have them half disconnected anyway. Do you have original tie rods? How many miles?
Old 10-27-11, 10:04 AM
paulwall86
paulwall86's Avatar
Default Replacing Tie Rods
Replacing Inner and outter tie rods. Anyone suggest something else to replace while Im doing this in order to help ride quality?
Thanks
Old 10-27-11, 10:35 AM
curepunx
curepunx's Avatar
Depending on the mileage of your LS and the service history/last time you replaced other suspension/steering parts, I'd recommend replacing the lower ball joints while you're there. (Unless they were replaced not so long ago)...Here's a link to some affordable OEM balljoints. I'm located in So-cal and it came to approx. $111 (for BOTH) shipped to my door. Goodluck!
Lexus Parts World
Old 10-27-11, 11:21 AM
paulwall86
paulwall86's Avatar
Cool thanks guys.. Anyone know how bad it is to replace the front strut rod bushing?
Old 10-27-11, 11:35 AM
curepunx
curepunx's Avatar
The front strut rod "cushion(s)" are quite pricey (varies between 130-150 EACH) but their installation is not too difficult. Balljoints and tie rods are definitely a lot more involved. My mechanic installed the cushions several years ago (i provided the parts) and he completed both within 15 minutes. If you're using handtools, it will require more time and effort. Remember to search here and via the web for the best prices on these parts. Sewell Lexus, Carson Toyota and Ebay are all your friends. lol...
Cheers!
Old 10-27-11, 11:44 AM
midwest2
midwest2's Avatar
They are easy to take off unless the car has spent alot of its life in snow country. In that case the front bolts can become seized to the sleeve in the bushing and no amount of force will break it loose because the rubber in the bushing will "give" and spin before it breaks loose. I had to cut mine out with a torch.
My rear lower shock mount bolt was also seized to the sleeve. In that case I was able to use a hand grinder to cut the bolts out.
Old 10-27-11, 12:43 PM
paulwall86
paulwall86's Avatar
Ok well I have not replaced any ball joints yet. I have 216,000 miles and I have done the actual struts on the front, new rotors brakes and calipers, I have had on cushion replaced drivers side. Are there any good tutorial online to get a good grip on where its located and what I need to do? Thanks
Old 10-27-11, 02:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
why are you replacing inner/outer tie rods and not just rebuilding the rack too?
Old 10-27-11, 02:40 PM
RA40
Super Moderator
RA40's Avatar
What are the current suspension symptoms/problems?
Old 10-27-11, 05:00 PM
paulwall86
paulwall86's Avatar
How difficult is it to replace the rack? and where can I get one for a great price? any online tutorials?
The symptoms are that the wheels shake a little and when you press the brake the steering wheel shakes./
Old 10-27-11, 05:24 PM
PureDrifter
BahHumBug
....have the wheels balanced and the rotors cut.
unless there's visible play and/or leaking seals/boots you shouldnt need to replace anything in the steering gear.
Old 10-27-11, 05:33 PM
AussieAuto
AussieAuto's Avatar
It sounds like it's the discs if it's when you touch the brakes.
Old 10-27-11, 05:44 PM
paulwall86
paulwall86's Avatar
I just replaced the rotors brakes and calipers
Old 10-27-11, 06:02 PM
AussieAuto
AussieAuto's Avatar
Then did you feel any movement in the tie rods? when you rock the wheel?
dicer
12
09-08-16 02:32 PM
luda42688
Suspension and Brakes
14
03-08-16 02:17 PM
Zodiac
11-20-13 12:33 PM
jayr0422
14
04-10-09 12:21 PM
Lettuce
10-08-08 09:41 AM
Quick Reply: 91 ls400 replacing both inner and outter tie rods
