Help! upgraded to nav now no antenna raise
Old 10-24-11, 05:48 AM
Arthurt
Arthurt's Avatar
Default Help! upgraded to nav now no antenna raise
Help!!
Upgraded head unit to Pioneer X930BT this weekend and everything is working great except now the anttenna will not raise when unit is powered??? Anyone run across this issue?
Old 10-24-11, 06:01 AM
lex2001
lex2001's Avatar
It has got to be a simple power on/off switch that is separate from the antenna. You have your antenna wire (for signal) plugged into the radio but there has to be a separate power wire that runs to the motor that raises and lowers the antenna. The previous radio had some type of integration that powered the antenna motor when you turned the radio on. I'll bet if you trace it back you will find it's not connected.
Old 10-24-11, 11:24 AM
RA40
Super Moderator
RA40's Avatar
Yup...check the antenna lead that runs from the head unit to the wire that powers the antenna.
Old 10-25-11, 08:09 AM
Arthurt
Arthurt's Avatar
I am hoping for the wire code for thoses signals. Does anyone know what they are??
Old 10-26-11, 11:49 PM
Dtwillis5
Dtwillis5's Avatar
I think its not hook up cause when the factory radio is on the antenna is up when its off its down, but you can have a tape in the deck and it going to be down. The antenna is a wire that look like one of them red, white, or yellow wires that go on the back off a DVD player see if its hook up
Old 10-27-11, 09:00 AM
lex2001
lex2001's Avatar
Here you go. This link should be helpful.
http://www.autotoys.com/New_Tech/DIY...er_antenna.htm
cep89
GX - 1st Gen (2004-2009)
10-16-21 07:34 AM
Oldsports
10-05-18 05:18 AM
dvra2
RX - 1st Gen (1999-2003)
04-13-18 05:47 PM
SCereal
01-12-12 05:02 PM
Quick Reply: Help! upgraded to nav now no antenna raise
