Timing Belt
Old 10-21-11, 07:14 PM
Zagman91
Zagman91's Avatar
Default Timing Belt
Hi everyone i have a 95 and its in pretty good shape. I got it from my dad about 5 years ago and he did the timing belt at 95,000 miles. It now has 120,000 miles on it. My question is when is the next time i should start thinking about doing the timing belt again.
Thanks
Old 10-21-11, 08:48 PM
sdwtchlvr
sdwtchlvr's Avatar
Every 90K...so at about 180K.
Old 10-21-11, 10:07 PM
RA40
Super Moderator
RA40's Avatar
Yup, 90K miles is the recommended interval.
Old 10-21-11, 10:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
there's also a time interval specified, but rarely have i seen the belt go due to age, it's more likely to be one of the bearings int eh belt system.
i'd just pull the timing belt cover off once a year to keep an eye on it, and keep an ear open for sounds of a dying bearing.
Old 10-22-11, 07:35 PM
AussieAuto
AussieAuto's Avatar
Second time around I would definately rec a water pump replacement too, they leak and over time can sieze. The leak is usually small but it is the begining of pump deteriation. so make sur you do it when you do the belt...
Old 07-05-23, 07:33 PM
JBell1
4th Gear
JBell1's Avatar
249k, just changing the belt, tensioners and pump now, for the first time.
mulasien
04-29-20 10:10 AM
Studiogeek
Performance & Maintenance
12
02-18-13 03:20 PM
RGP
04-29-11 08:41 PM
Farino81
06-09-09 08:54 PM
Quick Reply: Timing Belt
