Another EGR issue
Old 10-16-11, 10:56 AM
PFCTTZ
PFCTTZ's Avatar
Default Another EGR issue
I've used search, none of the threads I've seen apply to my issue -for the "use search" trolls
91 ls400 120k miles
I get a CEL code 71 if I reset the ECU it will stay off for about 50 miles, and will come on and off every 50-100 miles, I cleaned the little filter under the cap, but it didn't help.
any ideas or helpful experience would be great,
picture is related...the car in question
Old 10-16-11, 07:49 PM
btruong1
btruong1's Avatar
i have the same issue bro, i think i read somewhere that you could try cleaning the throttle bottle and some cases it cleared the EGR cel code. I am going to try that on mines next chance i get. Side question, what kind of mileage do you get with said problem, does it even affected it to normal?
Old 10-16-11, 08:20 PM
dtLS400
dtLS400's Avatar
When I took my car to the shop to get it worked on they also told me that it was given the egr CEL, he cleard it and I cleaned the filter. It stayed off for a few drives then when on the freeway it turned on when I turned on the cruise control. A few days later i changed air filter, plugs and rear brakes and the light has been off since. I drove to Los Angeles and back from north Cali and the light is still off. I'm thinking it was my plugs ...
Old 10-17-11, 06:35 AM
PFCTTZ
PFCTTZ's Avatar
so it could have nothing at all to do with the actual EGR? Mine started at about 110k
Old 10-17-11, 09:23 AM
dtLS400
dtLS400's Avatar
Possibly nothing at all. Good Thing I didn't get a new egr valve to replace it. When I checked my plugs they were oxidized a bit so I think that is what t was
Old 10-17-11, 09:36 AM
btruong1
btruong1's Avatar
i think most people try other things or are forced to, because the EGR pipe is prone to getting a break in it, but it is rather a PITA to change
Old 10-17-11, 03:06 PM
PFCTTZ
PFCTTZ's Avatar
I'll take off the intake check the throttle bodies, and check the spark plugs after work tomarrow, I guess I'll go from there
Old 10-24-11, 12:08 PM
dtLS400
dtLS400's Avatar
Before the code came up I had allready replaced my egr pipe, it was cracked in a couple spots due to overheating
michaelb20
SC- 1st Gen (1992-2000)
09-26-14 11:28 PM
jlawr
12-06-11 02:27 PM
dougEfresh
12
02-01-11 04:40 PM
cnynctry
RX - 1st Gen (1999-2003)
13
07-16-07 02:25 PM
Quick Reply: Another EGR issue
