Clucking,clicking sounds driver side?
Old 10-05-11, 02:10 PM
anesthesia
anesthesia's Avatar
Default Clucking,clicking sounds driver side?
I have a 99 ls400 curently has 85,000 mile' i been hearing this click,clunck noise on going down drive wat,u turn or over bump it bothers me, i took it to mechanic to have the driver side look at but every thing looks fine, dont see any leaks. What could this be? Mostly coming from driver side. I tried to do search but all kinds of things that it could be, figure i bring this back for open discussion
Thanks
Old 10-05-11, 02:11 PM
sickwidit
sickwidit's Avatar
i think i have the same problem..
Old 10-05-11, 03:38 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
please search guys.
front strut rod bushings for 95-00, and make sure the front subframe bolts are tightened.
Old 10-05-11, 06:29 PM
deanshark
deanshark's Avatar
What would you expect to see leaking from suspension parts? You aren't going to see if anything is bad just by looking, you need to jack it up, both fronts or both rears, and take a crow bar and try to move everything up and down side to side with lots of force, then you might hear what is wrong. Most common would be the bushings that PD mentioned but check any and all bushings b/c, in your own words; "but all kinds of things that it could be,"
Old 10-05-11, 08:55 PM
anesthesia
anesthesia's Avatar
Puredrifter, really appreciated, thanks again for the info.
SparksLex
Build Threads
14
10-24-13 02:25 PM
2jzfanatic
Suspension and Brakes
11-23-05 07:53 PM
Quick Reply: Clucking,clicking sounds driver side?
