trans shift solenoids
Old 09-27-11, 09:54 PM
piratebron
piratebron's Avatar
Default trans shift solenoids
hello, I have a 1990 LS 400 with 225K It`s in great shape but I am having the classic shift problems that mean the shift solenoid (s) is going out. Where is a good place to get new shift solenoids. Also is there a good tutorial out there (with lots of pics) showing how many, where they are, and how to replace them?
Thanks
Old 09-28-11, 04:15 AM
Raddison
Raddison's Avatar
The classic problems? I haven't heard of such a thing, enlighten me?
Did your car throw a code? Did you check said code? If not, how can you be certain that the solenoids are going out?
I just searched around and haven't found a tutorial. Find it in your heart and pick up a camera when you go to do it, help all of us LS owners out!
Old 09-28-11, 05:13 AM
Yotarip
Yotarip's Avatar
Shift solenoids are very easy to change. Same procedure as changing the trans filter. The most difficult part will be disconnecting the electrical lead at the solenoid without breaking the clip. If it breaks, tiny zipties can be used to secure the connection.
Old 09-28-11, 07:45 AM
emarknot
emarknot's Avatar
and yes, there is a diy on changing the shift seloniods
Old 09-28-11, 02:02 PM
curepunx
curepunx's Avatar
When my shift solenoids were beginning to act up...the symptoms were clear and more than anything, there was a constant CEL. Check your codes first to make sure its showing up the proper problem area.
I went ahead and replaced the trans-filter while i was at it. (not an expensive part) and finish replacing the solenoids. they were some itty-bitty little things.
I ordered from here http://www.bulkpart.com/Merchant2/me...e=A340solenoid
After everything, the car has been running well (trans-wise).
It's the solenoid kit for the A341E transmission.
Goodluck!
Old 09-28-11, 09:16 PM
btruong1
btruong1's Avatar
from the SC400 forum, but same trans and procedure
https://www.clublexus.com/forums/sc-...placement.html
Old 03-04-12, 02:05 PM
fasteddy50
fasteddy50's Avatar
F I N A L L Y S O M E O N E P O S T E D P I C T U R E S. Thanks Man. Very helpful. Ed
Old 03-04-12, 03:05 PM
ariasuriah
ariasuriah's Avatar
Thanks
Are you 100% positive it's the solenoids? I say check the wire in the trunk first to see if there is any damage to the harness at all. Trust me.
The solenoids are super easy to change if they do need to be replaced. Definitely have some mini zip ties handy for sure, as the harness connectors will most definitely snap 100% guaranteed. Be sure to change the filter as well. Good luck.
Old 03-04-12, 08:45 PM
305ls400
305ls400's Avatar
what cable in the trunk??
Old 03-05-12, 02:25 AM
billydpowe
billydpowe's Avatar
you must be new here.....
do a search on trunk hinge wiring, or read the stickies
Old 03-05-12, 03:58 AM
atlls400
atlls400's Avatar
Thanks
Been talking to alot of Tranny repair shops and they seen these thing throw codes for the solenoids and it's usually something else Like a whole rebuild more like. Specially with 225K
Good Luck I hope it's just the solenoids and def do the Filter as well
Old 03-05-12, 11:06 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
try talking to shops that actually know these cars.
i had a single solenoid replaced >40k miles ago (as the Wiring harness to it was dead and it was replaced as a precaution) and the car hasnt missed a beat since.
Old 03-08-20, 05:35 PM
hhadden
hhadden's Avatar
What do you mean by check the wire harness in the trunk? I am having similar problems with my 1992 LS400. It runs great motor wise its just having shifting issues it is slow on the take off then it shifts weird a combo of hard and long. Sometimes you have to slightly let off the gas for it to shift . I fell its minor because its not slipping so to say and when you mash into it it drops down in the passing gear. I got it up to 70mph today on a test drive after i removed and cleaned the throttle body. Any clue on what my issue might be ????
Old 03-09-20, 09:30 AM
sha4000
sha4000's Avatar
Have you ever drained and filled the transmission fluid?
This is what he means when he says to check the harness.
​​​​​​https://www.clublexus.com/forums/ls-...-in-trunk.html
Old 03-09-20, 09:57 AM
YODAONE
YODAONE's Avatar
Default Transmission solenoid wire harness
Thanks
The 1999 LS400 A650-E transmission employs a fluid temperature sensor that is prone to diminish with age.
The A340 solenoid harness probably uses similar sensor.
Our transmissions shift differently when cold.
Said sensor may be a contributing factor if it cannot properly direct the ECU.
Quick Reply: trans shift solenoids
