my ls400 died :( help
Old 09-27-11, 07:05 AM
nurvcom
nurvcom's Avatar
Default my ls400 died :( help
ok i was coming home from work and car start to act like it running out of gas and chuging and wont rev stay low and barlly moves then bammm i have 1 sec of fulll throttle and back to nothing and bam 1 sec of full
it took me 15min to do 3 blocks and in park when it does same thing sounds like it back firing and cant do anything
no check light (and chk light works)
1990 lexus ls400
Old 09-27-11, 07:38 AM
tcmzodiac
tcmzodiac's Avatar
Start with the easy stuff...bad gas? Was your gas tank really low when this happened..could be junk from the tank?
Old 09-27-11, 01:27 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
it's magic.
seriously, you give us nothing more than "it sputtered, went slow, then died" don't do any troubleshooting and expect us to be able to tell you what happened?
go check out the ignition/fuel system and figure out if you lost gas, spark, or air.
Old 09-27-11, 02:25 PM
deanshark
deanshark's Avatar
Hard to tell with the info we got but my car did this a couple different times. Once it was, eh, just the fuel filter clogged. The other time,.....the timing belt jumped. So it could be just a $20 fuel filter, or it could be $500 in parts for a T-belt/water pump job. Ya need to diagnose it a little bit to find out if ya have spark and/or fuel getting to each cylinder. Even though the CEL isn't lit you should check for codes anyway incase any are stored in there. I would check for spark first then go from there. Does it idle and then die when you give it gas or does it just not run at all?
bwireless
05-20-12 04:24 PM
zoomnos2
05-30-11 03:12 AM
GA_Lexus
03-10-11 10:41 AM
1996LS400
05-09-10 06:29 AM
jagjane
10-30-09 06:27 PM
Quick Reply: my ls400 died :( help
