Braking vibration after new rotors
Old 09-20-11, 04:21 PM
shajbot
shajbot's Avatar
Default Braking vibration after new rotors
About a month ago I replaced the rear rotors on my 93 LS because of a strong vibration that could be felt in the brake pedal and the seat that was going on for awhile after I picked up the car. I also replaced brake pads all around because they were almost worn. Right after that the vibration subsided for a couple of day but returned again, only this time, it's only a slight vibration at braking now. I'm thinking if the rotors are brand-new it should be vibration free. So maybe it's not the rotor but something else. I noticed when I removed the old rotors to put in the the new ones, the wheel hubs looks very rusted at the surface. Could this rust cause the rotor to sit unevenly on the hub causing the wrapped rotor vibration when braking? And yes I searched. Thank you in advance for any input.
Old 09-20-11, 04:32 PM
LiCelsior
Retired
LiCelsior's Avatar
hmm did u break them in properly?
Old 09-20-11, 04:36 PM
shajbot
shajbot's Avatar
I think I did...hard braking 60-5, 40-5,30-5 about a minutes or two in between runs for a couple of time.
Old 09-20-11, 05:01 PM
LiCelsior
Retired
LiCelsior's Avatar
hmm, maybe one of the calipers is seized?
Old 09-20-11, 06:39 PM
shajbot
shajbot's Avatar
Pretty sure the calipers were moving with the slider pins when I had the calipers apart.
Old 09-20-11, 10:16 PM
RA40
Super Moderator
RA40's Avatar
Clean anyy surface rust off the hub that the rotor may contact as well as your wheels. Make sure the lugs are all torqued to the same spec.
Old 09-21-11, 07:27 AM
MrFuel
MrFuel's Avatar
Check your strut bushings. Mine did the same only on braking and it was my bushings were bad.
Old 09-21-11, 07:35 AM
AerialAce
AerialAce's Avatar
Why only the rear when the front takes about 70-80% of the brake abuse? Theirs a good chance the fronts are warped, its extremely common on 1st gens.
Old 09-21-11, 08:09 AM
billydpowe
billydpowe's Avatar
I have agree with MrFuel, check your strut bushings.
wdwilson10
Suspension and Brakes
21
10-29-14 09:10 PM
lxus4xms
02-08-09 10:53 PM
OneGuyInCA
RX - 1st Gen (1999-2003)
01-31-08 12:37 PM
deanbrown
12-18-06 01:22 PM
Quick Reply: Braking vibration after new rotors
