Clear coat coming off my 98 on rear driver door
Old 08-29-11, 05:44 AM
DK Audio
DK Audio's Avatar
Default Clear coat coming off my 98 on rear driver door
The clear coat on my 98 is coming off on the rear driver's side door. I want to do something before it continues to get worse. This is the only spot on the car that is doing it, any ideas on what I can do? I was thinking about sanding it down and getting some Lexus aerosol paint and clear coat, I was hoping I could just sand to the body line (edge) near the top of the door.
*After some searching it appears that Lexus didn't use a clear coat on their Black Onyx cars?! If the car doesn't even have a clear coat what is this peeling?
Uploaded with ImageShack.us
Old 08-29-11, 06:37 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
complete cleacoat failure, can't be saved.
you can make it look better by having a detailler compound the hell out of it and then layer it up with wax, but its just going to get worse (even if you keep it clean+waxed constantly). only solution is a PROPER repaint. none of this spray-can crap.
and heads up, Lexus/Toyota don't sell the paint they used on your car, they'll sell you a tiny tin of touch-up paint, but you can't paint with it. no such thing as "oem paint."
i used to think that 202 didnt have clearcoat but apparently they started to change that in the late 90s, my '99 does.
Old 08-29-11, 06:55 AM
DK Audio
DK Audio's Avatar
Great, obviously I cannot afford to repaint the whole door and would it even be worth it on a 98? It is close to moving down the door, I've had the car for coming up 2 years and it has gotten way worse. It is only on this door though.
Old 08-29-11, 08:00 AM
ThomasGS4
ThomasGS4's Avatar
Maybe the door was previously repainted cheaply.
Old 08-29-11, 09:54 AM
RA40
Super Moderator
RA40's Avatar
+1. Other areas would also be exhibiting this issue opposed to just one door.
Old 08-29-11, 02:38 PM
PureDrifter
BahHumBug
check the roof and rear bumper, that's where the paint gets the most abuse/exposure. if it's on the door it's probably elsewhere too. mine is showing similar failure though not quite as bad yet.
Old 08-29-11, 07:32 PM
chalels40o
chalels40o's Avatar
yup prolly was painted b4 wit a cheap paint
Old 08-29-11, 09:24 PM
RA40
Super Moderator
RA40's Avatar
PD do you have a clear bra on your bumpers? The UV protection helps but then, I've had mine re-sprayed so it is pretty fresh considering. The film on mine begins to get a faint yellow/amber hue at ~2 years. Obvious on the pearl white but the dark colors aren't obvious.
Old 08-29-11, 10:10 PM
PureDrifter
BahHumBug
no clearbra mike, my front's been resprayed once but the rear is all original, and the paint is just burning to hell.
Old 08-30-11, 02:21 PM
DK Audio
DK Audio's Avatar
There is a small spot or two on the hood and one on the trunk lid but nothing like that door, the other 3 doors aren't at all.
whoisrhp
CL of Southern California
13
10-14-08 11:10 AM
whoisrhp
Automotive Care & Detailing
10-09-08 10:05 AM
whoisrhp
10-09-08 09:20 AM
mousiee
05-18-08 06:21 PM
WhatYaGot
06-27-07 08:08 AM
Quick Reply: Clear coat coming off my 98 on rear driver door
