What do i need to get neg camber?
Old 08-23-11, 12:53 PM
kseipel
kseipel's Avatar
Default What do i need to get neg camber?
I'm getting coilovers in about a week and i will most likely need new suspension parts. I want some negative camber and don't know if i need camber arms or plates. How much they usually cost, etc...
Anybody willing to give this damsel in distress some insight?
Old 08-23-11, 01:24 PM
ren335
ren335's Avatar
I'm not sure about all that, but you could replace the suspension for bags. How much camber are you looking for? Like the extreme VIP style? or just so it looks flush?
Old 08-23-11, 02:57 PM
RA40
Super Moderator
RA40's Avatar
What wheels are on or will be on it? How low will you set it at?
That has some say in how much camber you want for running flush, poking, etc. The normal drop will bring in neg camber.
Old 08-23-11, 04:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
please only add as much camber as you need, adding too much will really just look stupid.
you can dial in a fair amount of camber on the LS in factory form, so what is your wheel setup that you think you'll need more than that...
Old 08-24-11, 05:59 AM
ray316
ray316's Avatar
i'm also curious about this ive read on the forums that you can dial in extra negative camber with the factory suspension components how does it work??
Old 08-24-11, 07:55 AM
Rdrcr
Rdrcr's Avatar
Good to know. My LS has positive camber at the moment and I'm destroying my tires...I need some negative camber to get some even tire wear...perhaps I shouldn't drive it like my other vehicles...
Mike
Old 08-24-11, 10:02 AM
Rey
Rey's Avatar
Front double wishbone does not benefit from camber plates unless youre trying to increase distance between the coilover and spindle. You can get a decent amount of negative camber in the rear with stock components. For the front look into rca/camber adapters. Nagisa makes some. If you wanna go crazy oni style then fully adjustable arms from Nagisa are for you, but theyre not cheap and for an entire set of arms will cost more then a lot of these ls400s are worth.
http://www.more-japan.com/nagisa-aut...n-lexus-ls400/
Old 08-24-11, 11:32 AM
RA40
Super Moderator
RA40's Avatar
What year is yours?
There is a limited camber adjustment at least from the 95-00. Dunno how the first gens are.
Old 08-24-11, 01:42 PM
radiokilla
radiokilla's Avatar
1st gen you can get almost -5 out of stock camber adjustment (natural camber included)
Old 08-24-11, 01:43 PM
PureDrifter
BahHumBug
really mike? with my ride height i'm maxed out at ~ -4ish* in the rear with the settings at max POSITIVE.
Old 08-24-11, 01:54 PM
LiCelsior
Retired
LiCelsior's Avatar
could get around that -5* mark also.
Old 08-24-11, 04:18 PM
S30ZG
S30ZG's Avatar
I got -6 out of my eccentric bolts before having the alignment dialed in. I'm now at -5.9 and -5.8 in the rear.
I'll be interested to see what the front maxes out at w/o RCAs. I had -5.5 up front with them.
Old 08-24-11, 05:02 PM
tenchu
tenchu's Avatar
Yeah getting negative camber whilst lowered in a UCF10 (not sure about newer models) should be no issue with stock eccentrics. POSITIVE camber, likely even 0 camber when a substantial drop, would likely be difficult, but negative should come naturally.
Old 08-24-11, 06:30 PM
radiokilla
radiokilla's Avatar
Until the accident.........trololol
Old 08-24-11, 07:29 PM
KevinE.
KevinE.'s Avatar
I'm on stock adjustments with natural camber, I'm pretty sure it's not even maxed out
Quick Reply: What do i need to get neg camber?
