Has anyone had good luck with a used AC compressor?
Old 08-02-11, 03:46 PM
darimura
darimura's Avatar
Default Has anyone had good luck with a used AC compressor?
I am looking to get a used AC compressor just to get through the short term, Has anyone had reasonable good luck with it. I will be DIY the whole process and will be filling the system with ES12A.
Old 08-02-11, 05:36 PM
sam12345
sam12345's Avatar
I did on my Avalon but it's the luck of the draw
Old 08-02-11, 07:14 PM
emarknot
emarknot's Avatar
I agree. its all upto the compressor you get. could go a day could go another year or whatever..
the last used comp i installed, was on a mazda...lasted approx 7 months.
it was the ol lady's sister's car
Old 08-02-11, 08:36 PM
sdls
sdls's Avatar
I've put an A/C compressor from a 1991 LS400 into a 1995 LS400 - and charged the system up at home, without properly evacuating the system and getting moisture out.
It's been working fine for the past year and a half.
Old 08-02-11, 08:54 PM
RA40
Super Moderator
RA40's Avatar
I say do it right, the time you take to do this and if the compressor goes south, the drill begins again.
An aside, is the system fully compatible with the ES12A? This propane based refrigerant I'm not familiar with. Having it in proximity to heat should a leak strong enough occur...brrrr.
Old 08-03-11, 07:48 AM
acidfire52
acidfire52's Avatar
LOL, did the exact same thing. Working great.
Old 08-03-11, 04:34 PM
sam12345
sam12345's Avatar
While on the subject my compressor slightly growls when on sounds like a power steering pump low on fluid but not as loud it works great and has made this noise since I bought the car almost 2 years ago it's an r12 that's been converted to 134 is this normal any one else have this issue?
Old 08-03-11, 08:50 PM
willhickey
willhickey's Avatar
if its noisy id let it ride until it blows up.... its not normal but with retrofits and the mixture of oils i see it alot at work..
Lonely77
GX - 1st Gen (2004-2009)
06-21-18 08:10 PM
hazepurple
11-27-11 07:48 PM
flexspeed
07-30-09 10:14 PM
damon
27
09-05-08 04:50 AM
1LS400Lexus1
04-13-03 04:58 PM
Quick Reply: Has anyone had good luck with a used AC compressor?
