Will 265/45/18's fit?
Old 08-02-11, 12:58 PM
Rdrcr
Rdrcr's Avatar
Default Will 265/45/18's fit?
I'll be installing 2005 LS430 18 inch wheels on my '96 LS. Will 265/45/18's fit with the OEM wheel offset?
I quickly searched and didn't find any '95-'97 LS's running the LS430 18 inch wheels with larger than 245's on the factory/OEM height/springs. I did read some previous threads that stated 275's required some work.
Mike
Old 08-02-11, 01:58 PM
RA40
Super Moderator
RA40's Avatar
If you aren't lowered, it shouldn't be a problem. The rim width is outside the recommended width at 8.5-10, 9" optimal. They will have that fat look. A 265/40-18 is a better match in diameter but you'll need a wider wheel for proper, though conservative fitment.
What tires are you thinking? Tire Rack in the size you listed shows the MichelinPilot HX MXM4 265/45-18 as the only offering. I'd suggest a 245/45 or 245/40 size with the LS430 wheels.
Old 08-02-11, 02:05 PM
Rdrcr
Rdrcr's Avatar
LOL, yes, that's the tire, Michelin Pilot HX MXM4 265/45-18. I was able to get a brand new set of these tires for free.
I agree that the 245/40-45 would be the proper tire but, I don't want to spend additional monies if I don't need to.
Mike
Old 08-02-11, 03:22 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
265/45-18 is too big, both in diameter and more importantly in this case, width.
the oem LS430 18s are 7.5" wide., which is a solid inch UNDER the minimum requirement for those tires (8.5in min).
sell them or trade them for some tires that are the proper size.
Old 08-02-11, 04:59 PM
Rdrcr
Rdrcr's Avatar
That's what I was afraid of...
I read that 0.5 inch is not too bad but, 1 inch narrower may be too much for the tires.
Mike
sparky3
07-12-19 01:21 PM
430THUNDER
04-04-14 04:17 AM
LS2k
04-14-09 10:55 PM
DanozLS430
06-09-08 07:45 PM
gsWarrior
GS - 1st Gen (1993-1997)
12-12-05 05:55 AM
Quick Reply: Will 265/45/18's fit?
