How do you replace a "LH" camshaft oil seal, and crankshaft seal. on 98 Ls400.
Old 07-22-11, 02:58 PM
PjLex
PjLex's Avatar
Exclamation How do you replace a "LH" camshaft oil seal, and crankshaft seal. on 98 Ls400.
I have read about many people saying they had done it or that it is a PITA. But I can't seem to find any directions. I have downloaded a shop manual and the move relevant section appears to be Removal of Cylinder Heads. Is there any other section in the shop manual that details.
A little background, I am changing the timing belt and water pump etc. I found more oil or grease under the timing belt covers and inside than I had hoped. I don't know if I am over reacting by thinking I should replace the crankshaft and LH camshaft seals. While removing timing belt and water pump I got coolant in many places and I when I took off the water pump the gasket was bad on the bottom. I'll include pictures and you can tell me.
Does any one had a link or tutorial about how to do this correctly. Is it really a PITA or are people just exaggerating it? How careful do you have to be with the vvt-i system.
I found numerous mentions of people saying do it , but not a lot of instruction on how to do it properly. I would also like to know how to replace crankshaft seal.
The first four pics are not cleaned, the last pic I took some degreaser to it and wiped it good with towel. But you can still see under the LH camshaft the residue oil and grime.
You help is greatly appreciated. Any and all advice is welcome. Thanks! Preston J.
Attached Thumbnails How do you replace a "LH" camshaft oil seal, and crankshaft seal.  on  98 Ls400.-dcp_7659.jpg   How do you replace a "LH" camshaft oil seal, and crankshaft seal.  on  98 Ls400.-dcp_7661.jpg   How do you replace a "LH" camshaft oil seal, and crankshaft seal.  on  98 Ls400.-dcp_7692.jpg   How do you replace a "LH" camshaft oil seal, and crankshaft seal.  on  98 Ls400.-dcp_7694.jpg   How do you replace a "LH" camshaft oil seal, and crankshaft seal.  on  98 Ls400.-dcp_7707.jpg
Old 07-22-11, 03:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the camshafts have to be taken off to replace the seal on vvt-i engines.
Old 07-22-11, 06:09 PM
billydpowe
billydpowe's Avatar
I found this.......
YOU check it out....
you need to:
1. remove the oil feed on the union bolt to the vvti sprocket. (some oil will come out so be prepared).
2. remove the nut cover on the vvti gear via 14mm hex socket
3. remove intake side valve cover, and hold the camshaft w/ a wrench
4. while you hold the wrench, remove the vvti gear via 10mm hex socket
5. DO NOT TOUCH THE 5 HEX BOLTS AROUND THE VVTI GEAR. IF YOU DO TOUCH IT, YOU'RE GOING TO NEED A NEW VVTI GEAR.
Old 07-22-11, 07:55 PM
bornpeace
bornpeace's Avatar
And remember to get a service bolt to lock sub-gear on exhaust camshaft if not you will have trouble putting it back. Pull the bearing cap straight up so that you dont damage the oil control valve filter. All the bearing caps a marked make sure you put them back where they belong.
I have a question, why is the left side(bank 1) the bank with most problem? (cam seal, o2 sensor, valve cover gasket) My bank 2 seems to have no problems
Old 07-26-11, 05:49 AM
86lumbee
86lumbee's Avatar
u most remove the camshaft to change the seals
Old 07-28-11, 05:38 PM
PjLex
PjLex's Avatar
I am finishing up the Camshaft oil seals for both LH and Rh. I am at the end of it I have one question. How much do I torque the valve cover bolts? When I took it off they were on very loosely. With out oil leaking too. I have searched in the shop manual but couldn't find it.
Old 07-29-11, 03:57 AM
deanshark
deanshark's Avatar
I posted in your other thread but incase someone searches for this in the future, the torque for the valve covers is 52 in-lb. (NOT ft lbs)
Old 10-12-13, 07:41 AM
billydpowe
billydpowe's Avatar
Thanks PD, you are doing a great job for us..... and we thank you for it.
FIPG (form in place gasket) is necessary as a sealer/gasket, but it cannot replace a seal, or seal up a seal.
we do not want to PATCH up our cars, just fix them as best as we can, and as cheap as we can...
Old 10-12-13, 06:05 PM
GSKaplan
GSKaplan's Avatar
Note: If the bolts felt loose when you remove them it generally means that the gasket/washer on the valve cover bolts have hardened and should be replaced.
Heykw
IS - 1st Gen (2001-2005)
03-04-24 05:23 PM
spo0k
03-19-18 10:45 AM
ScottGS300
10-15-15 01:23 AM
nick1126
12-03-11 08:01 PM
LVgs400
Maintenance
02-14-04 04:19 PM
Quick Reply: How do you replace a "LH" camshaft oil seal, and crankshaft seal. on 98 Ls400.
