Strut rod replacement?
Old 07-19-11, 09:30 PM
396chevy
396chevy's Avatar
Default Strut rod replacement?
Whats the best way to replace my strut rods? 2000 Ls. I searched but couldn't find any good instructions. Thanks
Old 07-19-11, 10:25 PM
bornpeace
bornpeace's Avatar
Get a marker, some sockets(22mm, 19mm, 17mm), jack stand, breaker bar, torque wrench, and 21mm socket because i like to torque my lug nuts
1. Put the car on jack stand
2. Remove the front tires
3. See if you can remove the strut bracket without taking the knuckle and strut out. (if you have to take the knuckle out you may need a ball joint puller). I remember PD said you can remove the bracket without taking the knuckle out, it will be tight so play with it
4. Mark the alignment or you will have to do alignment when your done(i assume you know this)
5. You may need a impact wrench or a good breaker bar to take the caster bolt out(remember is torqued at 134 ft.lbf) (camber is torqued at 185 ft.lbf)
6. You may need to remove the fender liner to get more room
Hope this help, the hardest part i think is to remove the strut bracket
Old 07-20-11, 09:09 AM
billydpowe
billydpowe's Avatar
here is 173 pages about Strut rod and/or bushings...
https://www.clublexus.com/forums/sea...archid=6878535
Old 07-20-11, 09:38 AM
bornpeace
bornpeace's Avatar
I was about to tell him to go search but i realize non of the search result show how to remove the strut rod.
Old 07-20-11, 12:25 PM
GSquicksilver
GSquicksilver's Avatar
are you referring to the hood strut rods or the actual suspension struts?
Old 07-20-11, 01:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
neither, the suspension Strut Rod. (aka caster rod)
Old 07-20-11, 02:15 PM
billydpowe
billydpowe's Avatar
this might help:
File Type: doc
Old 07-21-11, 10:58 AM
wcraig18
wcraig18's Avatar
How about replacing the struts that hold up the hood in the engine compartment? Also, where is the best place to buy them. Thanks, Bill
Old 07-21-11, 11:03 AM
billydpowe
billydpowe's Avatar
I got mine from ebay $30. all you need is a wrench.
Old 07-21-11, 12:20 PM
PureDrifter
BahHumBug
how about searching the forum and not threadjacking?
Old 07-25-11, 11:52 AM
wcraig18
wcraig18's Avatar
Not sure if I thanked you. The struts are on order and the wrench is in hand. Do you have any experience with replacing the radio antenna in the trunk? B/R, Bill
Old 07-25-11, 03:53 PM
LexFather
Guest
Posts: n/a
STAY ON TOPIC. Last time being warned. Thanks
Old 01-30-20, 03:35 PM
kambam3627
kambam3627's Avatar
shuuuuuuuuuttttt up.
Old 01-30-20, 04:26 PM
Sin1UZFE
Sin1UZFE's Avatar
This was basically 9 years ago
Billyboi (10-01-21)
Old 01-30-20, 09:23 PM
kambam3627
kambam3627's Avatar
I know, still felt necessary.
Billyboi (10-01-21)
kuziwk
03-26-11 05:35 PM
rob22
01-27-11 11:16 PM
Ariyanna
12-11-09 01:41 PM
youngstah
GS - 1st Gen (1993-1997)
05-01-09 08:20 PM
Shinchan
08-23-01 03:31 PM
Quick Reply: Strut rod replacement?
