Complete List Of fault codes? for 96LS
Old 07-17-11, 01:56 AM
ccorogers
ccorogers's Avatar
Exclamation Complete List Of fault codes? for 96LS
I have looked for a while and have yet to find a credible source of information on a complete list of fault codes for my 96LS. wanting to print them to put in the car. any links or help is a big thanks.
Old 07-17-11, 05:34 AM
steve2006
steve2006's Avatar
Your 96 LS uses OBDII codes which are common for all models using this diagnostic code system a google search will provide all the common codes, there are some specific manufacture codes but these are not normally needed on a general diagnosis.
I can't understand why you want to keep a copy in the car as you will then need a code reader to go with them and a full set of tools and spare parts if you want to do the repair when a code flags up.
Do what most people do, check the codes if and when the management light comes on, chances are if it does it won't leave you stranded and it won't very often appear on a Lexus!
Old 07-17-11, 06:47 AM
deanshark
deanshark's Avatar
How long of a while did you look, 10 seconds? Maybe not b/c I found this in 10 seconds; http://engine-codes.com/make/lexus That's only 1 of the many that showed up, but you only need 1. I also don't understand why you would keep it in the car b/c it doesn't tell you what to fix. For that you would have to search.
Old 07-17-11, 11:59 AM
billydpowe
billydpowe's Avatar
probably a half empty sort of guy, living in fear of the unknown, relax, you have the best automobile you could own.... Cheers.....
FRSTDJ
12-03-18 07:16 PM
tarheel49
05-09-17 03:57 PM
CallmeQ
GS - 1st Gen (1993-1997)
09-26-09 12:19 PM
forcefed86
Performance & Maintenance
01-05-08 03:41 PM
RUDENESS
10-05-04 01:36 PM
Quick Reply: Complete List Of fault codes? for 96LS
