Oil Controler Filter... Where are they???
Old 07-12-11, 12:55 PM
rishi
rishi's Avatar
Default Oil Controler Filter... Where are they???
I can't seem to find these filters?? where the heck are they? any help please?
Old 07-12-11, 01:12 PM
rishi
rishi's Avatar
this is for a 1998 LS400...
Old 07-12-11, 01:35 PM
skperformance
skperformance's Avatar
are you sure you need a filter or the mesh screen on the side of the oil control valves for the VVT-i .
Always a good thing to post what and why your looking for an answer .
Old 07-13-11, 03:18 AM
billydpowe
billydpowe's Avatar
what screen??
Attached Thumbnails Oil Controler Filter... Where are they???-ocv1.jpg   Oil Controler Filter... Where are they???-oil-control-valve.jpg
Old 07-14-11, 09:10 AM
rishi
rishi's Avatar
these filters.... where do they go?
Attached Thumbnails Oil Controler Filter... Where are they???-screen-shot-2011-07-14-at-11.09.44-am.jpg
Old 07-14-11, 10:51 AM
techtalk
techtalk's Avatar
rishi,
If I recall correctly, the oil control filters are located underneath the oil control valve, which is located at the transmission end of the cylinder head. (refer to this LS400 cylinder head diagram for further clarification)
Hope this helps you out a bit buddy
Old 07-14-11, 11:04 AM
billydpowe
billydpowe's Avatar
The oil control valves for the vvt system, are located on the front of the cyl heads, one for each head.. NOW.. I have never seen these screens... I have taken out my valves and cleaned them PLUS cleaned the chamber they go in, BUT I have never seen these screens. IF YOU get them out, let us know. the following shows where they are located.
Attached Thumbnails Oil Controler Filter... Where are they???-oil-controll-valve.jpg   Oil Controler Filter... Where are they???-ocv-loc.jpg   Oil Controler Filter... Where are they???-ocv.jpg
Old 07-14-11, 09:52 PM
rishi
rishi's Avatar
the car is throwing out 2 codes.. P1663 Oil Control Valve Circuit (bank 2) and P1354 Variable Valve Timing System Fault... because of this i have the "Check VSC" light on as well along with the check engine light...
I always hear about people cleaning out these filters... what are they talking about? how did you clean those valves? what did you use... I pulled them out yesterday and they looked fine to me.. didnt think about cleaning it or anything maybe i'll try that.
also on another note.. i think i need a new starter... the car starts sometimes, and sometimes doesn't turn anything over.. i turn the key and nothing... i hear the car locking and unlocking is it some security issue? i first thought it was some electrical problem.. but now im thinking its the starter. any ideas..
Thanks Billy!
Old 07-15-11, 04:43 AM
billydpowe
billydpowe's Avatar
ideas I "got". remedys? maybe..
I took my valves (ocv) out, cleaned them with carb cleaner, making sure the spring action was working (snappy) then got my mechanical fingers (photo) pinched a small piece of cloth, soaked it with carb cleaner and ran it up and down in the chamber, changing the dirty cloth until it came out clean. that fixed my cel & vsc lights.
On my starter, I replaced the solenoid contacts (photo) in both of my first two 99's, so far my third one is ok...
good luck
Attached Thumbnails Oil Controler Filter... Where are they???-mf.jpg   Oil Controler Filter... Where are they???-100_1792.jpg   Oil Controler Filter... Where are they???-100_1795.jpg
Old 03-03-13, 01:55 PM
masagsxr
masagsxr's Avatar
Did you ever find out where this goes on your LS4? Have the same issue with my SC4 but P1349. I tested the OCV and still functioning properly. I'm due for a T-Belt job tho and I've read somewhere that the belt may have stretched or skip a tooth which can also throw P1349.
Old 03-04-13, 05:22 AM
rishi
rishi's Avatar
i never figured where those screens went... i just replaced replaced the actual Oil control valves.. the ones pictured in billys first post... solved my code.. I sill have those filters laying around somehwere lol.
Old 04-18-13, 10:00 PM
johnniehd
johnniehd's Avatar
I have the same problem. I took out the OCV and cleaned it. Still have the same issues of rough idling. The VSC and CEL still come on. Code P1349 came up when scanned. I can't seem to find anywhere a pic or "clear" diagram of the OCV filter placement.
Old 04-19-13, 08:05 PM
billydpowe
billydpowe's Avatar
The oil control valve is listed on this photo with a circle around it
Attached Thumbnails Oil Controler Filter... Where are they???-oilcontrolvalvefilter.jpg
Old 04-20-13, 12:00 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Billy, that's a 2JZ-GE, straight 6 lol.
Old 04-20-13, 04:28 PM
billydpowe
billydpowe's Avatar
yep, but it is the only oil control valve filter screen I have ever seen...... I just found it on the net.... lol
Quick Reply: Oil Controler Filter... Where are they???
