Need urgent help with my ucf10 / ls400
Old 07-08-11, 09:23 PM
gambooby
gambooby's Avatar
Default Need urgent help with my ucf10 / ls400
Hey everyone i was wondering how do i remove the bottom portion of rubber on the lowest part of my ucf10? Like the black part? heres some pics
I tried a little bit to rip it off hahah but i doubt thats a right way to do it
Old 07-09-11, 04:02 AM
billydpowe
billydpowe's Avatar
Urgent Help? what searches have you tried?
have you even tried taking off the panels so you can see what is holding it on?
yours is an older model, but my book shows this:
maybe it will help
File Type: pdf
Old 07-09-11, 05:34 AM
Bradster
Bradster's Avatar
I believe the lower rubber portion of the panel IS part of the panel..I have one right here in my house and it seems riveted to the cladding..
Old 07-09-11, 06:30 AM
deanshark
deanshark's Avatar
That rubber piece is attached on the inside of door outside moulding (panel) with rivets. This is from my 93 manual; To take off the panel on the front door you need to
remove 2 screws from inside lower door panel. (rear door is 2 screws, 1 nut) Using a moulding remover, pry out the moulding from the lower side. (manual says upper side but that's wrong)
Drill out the rivets
Remove rivets.
Install is reverse
Old 07-09-11, 07:42 AM
steve2006
steve2006's Avatar
And urgent help would be something like you have broken down on an ice road in Alaska with temperatures below -60 or you car is on fire.
Old 07-09-11, 07:59 AM
deanshark
deanshark's Avatar
Well, he did post at midnight so . Don't want to get scratches on the door in the middle of the night. (Idk exactly where he's from though)
Old 07-09-11, 10:06 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
congratulations you have ensured that nobody is going to take any more of your "urgent" threads seriously.
Old 07-09-11, 02:21 PM
gambooby
gambooby's Avatar
hahah thanks everyone and i was trying fix my car up as fast as i can... so i guess its not really urgent :/ but thanks again! ill try all methods you guys recommended
doodoo
04-07-15 01:25 PM
brandoe91
04-21-10 03:21 PM
Aristo300
03-22-08 10:30 AM
maximussp
01-24-07 05:43 PM
plparrish
01-16-05 11:09 PM
Quick Reply: Need urgent help with my ucf10 / ls400
