timing marks
Old 06-19-11, 07:57 PM
jlegan
jlegan's Avatar
Default timing marks
so I replaced the timing belt and water pump, plugs, wires, caps and rotors, got it all back together and it has bad spark knock, no power at all will barely even move and on top of that it is leaking coolent from the back of engine somewhere. looks like it leaking between where the block and trans go together. timing marks appear to be correct, wires are correct engine runs smooth until you give it gas please help.....
Old 06-20-11, 06:18 PM
jlegan
jlegan's Avatar
bump......
Old 06-20-11, 06:24 PM
tenchu
tenchu's Avatar
Did it run fine BEFORE you changed the tbelt?
Old 06-20-11, 07:35 PM
randal
randal's Avatar
Go over all electrical connections and make sure you re-connected everything...wires, vacuum lines, etc.
As far as the leak, it could be coolant from a front hose which is wicking around the block and appearing to exit at the rear of the engine. Water can sometimes run in unusual channels. Look carefully. If not, it could be the coolant line running under the intake manifold. Perhaps it was disturbed and the rear O-ring is leaking?
incharlest
04-04-13 01:25 PM
daudi81
Performance & Maintenance
11-08-08 08:34 PM
poicow
02-05-08 07:45 PM
ta1972
11-06-07 10:25 AM
Bluesman
12-27-05 10:59 AM
Quick Reply: timing marks
