brake oil leak
Old 05-28-11, 06:11 PM
ricardo304
ricardo304's Avatar
Default brake oil leak
hello. my ls400 '90 is loosing brake fluid. i need to add every week, i've checked for the wheels, the rotors, the lines and there's not any leaking point. and i dont apreciate any leak on any where. i don't know where else to check. what could it be? i need to pump the pedal for a good braking feeling because if don't the pedal goes to the floor
Old 05-28-11, 06:30 PM
tenspeed
tenspeed's Avatar
Check behind the carpet at the brake pedal. Sometimes the master cylinder leaks down the firewall.
Old 05-28-11, 07:38 PM
RA40
RA40's Avatar
You may also be losing it under pressure form one of the intermediate lines and not at each corner. Have to get under the car and trace the brake lines for any signs.
Old 05-29-11, 03:57 AM
steve2006
steve2006's Avatar
Brake fluid can also leak into the brake booster and then get sucked into the intake and burnt by the engine so look for unusual exhaust smoke or smells,the under car pipes are well hidden in protective trunking making it difficult to spot pipe leaks.
A common way of locating a leak on calipers is to clamp the flexible brake hose off on individual wheels then see if the brakes still need pumping,if you find the brake pedal travel is less when say the right rear hose is clamped it is a good sign the fault lies around that area.
Have you replaced any brake pads recently and pushed the pistons back without first loosening the bleed nipple as this can cause the master cylinder seals to turn/distort.
Old 05-29-11, 07:03 AM
python
python's Avatar
if it is in fact going into ur booster as steve said..it can and will ruin ur cats
alohaman
12-10-18 05:03 PM
sleeper408
Suspension and Brakes
08-12-13 11:42 AM
OG Dada
13
11-23-12 12:36 PM
GoCarSc300
04-16-09 03:11 PM
Bane
06-13-05 01:06 PM
Quick Reply: brake oil leak
