UCF10 HID install question (how to get hi/low function)
Old 07-12-12, 05:43 AM
  #31
johnnyg66
johnnyg66's Avatar
Originally Posted by smix
this is probably a stupid question but i am a n00b with LS and i like to make sure of things before i mess with it lol , so this plug that you reverse the wires. It's the plug of the cars headlight harness that plugs into the hid bulb harness right?
Yes it is the socket to the headlight itself. He saying to reverse the wire on the HID kit socket adapter not the oem socket. I did what he did still never got my fogs to work. I ended up cutting off the sockets and replaced them with a later socket. All said and done never got the fogs to work with HID's.
Went back to halogens. May be a better HID kit sometime and try again.
Old 11-29-12, 11:56 AM
  #32
smix
smix's Avatar
ok so i finally did my headlights following what tenchu told us about reversing the pins in the harness. Did that with High and Low HIDs with the high beam as a halogen bulb. When i turn on my headlights the lowbeam is on correctly but then when i turn on my high beams, the driver side doesnt change and the passenger side changes halfway and starts flashing rapidly with both high and low on at the same time but really dim. Also my fog lights dont work either way, everything is good tho nothing blown. But does anyone know why my high beams dont work and why the right one starts flashing? Also, can a high and low beam bulb use a single beam ballast?
leedw14
CT 200h Model (2011-2017)
01-09-15 09:25 AM
kpkim01
Lighting
12-09-09 12:26 PM
xsohaib
04-12-09 08:49 PM
rlsrt-4
Lighting
05-04-08 01:46 PM
George.S.
GS - 1st Gen (1993-1997)
15
09-24-07 12:45 AM
Quick Reply: UCF10 HID install question (how to get hi/low function)
