Signal/Parking light problems
Old 05-08-11, 08:06 PM
tenchu
tenchu's Avatar
Default Signal/Parking light problems
I just picked up a 90 LS400 last night, when I got it, the signals weren't working, it was missing the fuse, and the front passenger bulb. The front drivers bulb was un-plugged. I replaced the bulbs, and the fuse, and everything was great (so I thought).
I decided to check all the other lights to make sure everything worked. All but the passenger reverse light work (even tried a new bulb) but thats not my concern right now. When I turned on the fogs (I think this is what triggered this **** storm) the parking light stopped working. I couldn't figure it out. I found a fuse box cover on eBay to copy the diagram off of, is this the correct diagram I need?
Now, if I turn the parking lights on, nothing happens. If I turn the signals on, nothing happens. If I turn the parking lights on, AND the RIGHT (ONLY the right) signal on, the parking lights come on (but not the signal). The hazards work as well, regardless of what lights are on.
The only fuse that affects the lights is the 15A fuse listed as ECU-B in that diagram. Can someone please help me? I need to get this tank back on the road, i'm moving 1,500 miles across the country in 2 weeks.
Old 05-09-11, 12:27 PM
tenchu
tenchu's Avatar
Update, apparently I was following the fuse diagram backwards *duh* so I re-arranged all the fuses properly, and now the turn signals work, along with the headlights, and the fog lights.
*BUT* the parking lights STILL do not work, unless the right turn signal is on. Please help!!
Old 05-09-11, 12:29 PM
tenchu
tenchu's Avatar
**double post**
Old 05-11-11, 06:04 PM
tenchu
tenchu's Avatar
In case anyone was curious (or this comes up again) it was my light stalk (the arm that controls the headlights, fog lights, turn signals, etc.)
I picked one up at a local scrap yard for $40 and it fixed the issue
Old 05-11-11, 06:54 PM
deanbrown
deanbrown's Avatar
Wow reading this thread was like a quick trip into the twilight zone or something. Glad you got it all sorted out in the end.
I had a reversing lights problem once and spent hours trying to find the problem, which ended up being a break in the wired under the carpet right in the middle of the car on the center console (how it broke there is still a mystery to me).
NimaM
09-30-12 09:55 AM
AndyG
03-04-11 10:30 AM
lexusscturbo
01-04-11 09:16 PM
wayne86
05-04-07 11:07 PM
Quick Reply: Signal/Parking light problems
