Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
93 LS 400 cuts out at 2000 rpm
Thread Tools Search this Thread
Old 05-07-11, 06:50 PM   #1
radiohound
Trader Score: (0)
Default 93 LS 400 cuts out at 2000 rpm
hello friends ... my 93 just stared acting up ... uphill or underload, it justs cuts out completely at 1500-2000 rpm ... and it cuts out when floored also ...
I can ease up and it catches back on ... but very puzzling ...
idles fine and revs clean in neutral ... just under load ...
new plugs, dist caps, rotors, timing belt, crank position and cam sensor changed within 3K ... car has 160K on it ... no problems before this
any thoughts or advice ... right now, can't go anywhere because car is dicey ...
thanks
frank
(radiohound@aol.com)
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
radiohound is offline   Reply With Quote
Old 05-07-11, 07:46 PM   #2
deanshark
Trader Score: (0)
Does it do it mainly when the car warms up? Do you hear pinging under load? My car was doing the same thing last year until I read this. http://www.clublexus.com/forums/ls40...nging-too.html As it says in the link, remove ECU fuse, unplug the AFM, replace fuse. Doing this will put the ECU in "fail safe" mode. If that is the problem don't drive for too long with the AFM unplugged. Mine is and it runs very rich, bad mileage, and I don't know for sure but I think it messed up my ECU. I can't retrieve codes from the CEL anymore, it just flashes like there are no codes stored even though I know there should be.
deanshark is offline   Reply With Quote
Old 05-08-11, 02:36 PM   #3
tonyfazt
Trader Score: (0)
another thing to consider would be the coil packs but usually if one goes out the rpms are reall low have u checked for codes
tonyfazt is offline   Reply With Quote
Old 05-13-11, 09:22 PM   #4
radiohound
Trader Score: (0)
Default progress, sort off..
well, thanks for the replies and guidance ...this is driving me crazy ..
I replaced the Coolant temperture sensor and cleaned the Throttle body and plenum.. a pita ..with all the hoses needing replacement ,, but it runs better but is still doing it under hard throttle.
I changed the plugs and wires and rotors and caps about 3K ago with non-lexus parts and am ready to take the factory plunge ..
I will check out your suggestions this weekend ...
thanks and keep 'em coming ...
Old 05-15-11, 12:03 PM   #5
radiohound
Trader Score: (0)
Default problem solved,I hope
so I changed out the Main Computer with one from a traction controlled car. Mine is not Traction Controlled.
Anyway, the hesitation I've been experiencing immediately disappeared. Hmmm. I ran it for a while but it seems to be all good, so far. I am a bit leery of declaring success. Anyway, here is the list of things I changed without making a difference:
Wires and plugs
rotors and caps
Fuel pump relay
Mass air sensor
Fuel filter (major PITA)
Engine coolant sensor ( mild PITA)
Cleaned Throttle Body of a 1/4 inch of scum build-up.
Changed associated vaccum and coolant hoses
Changed ECU unit ... and it cleared the hesitation and stumble at 1700 rpm ...
Plan to crack the old ECU and check out the capacitors ...there is a thread on the forums about the ones that can be replaced ...
Thanks for the help and hope this helps someone else
frank
Old 05-16-11, 05:17 AM   #6
Yotarip
Trader Score: (0)
I'm sure it's the caps in your ecu. I had the same problem. Bought a replacement ecu off ebay for $250 since I could not find one in my local junkyard at the time. Since then I have found 2 more good 93-94 ecu's in my local j/y for $24 each. I keep a spare in the glovebox for an emergency since I take my Lex on long family trips. I keep the other in my closet at home.
I see that DriftMotion offers ls400 ecu repairs. I just plan to take one of my extra ecu's to a local electronics repair shop to replace the caps before they go bad.
I plan to get a ucf20 next year and sell my ucf11.
Yotarip is offline   Reply With Quote
Old 05-17-11, 10:48 AM   #7
Dtwillis5
Trader Score: (0)
Dtwillis5's Avatar
willis da realest da realest
Default sound like my problem
Wires and plugs
rotors and caps
Fuel pump relay
Mass air sensor
frank
I have a problem some what like that .my car kills at 1700 rpm starts up fine I'm waiting on the junk yard to let me know when a 93-94 w/trac come in and go from there.
Dtwillis5 is offline   Reply With Quote
Old 08-11-11, 10:46 PM   #8
firefly
Trader Score: (0)
any update?
firefly is offline   Reply With Quote
Old 09-11-12, 05:21 PM   #9
shoob
Trader Score: (0)
shoob's Avatar
same issue, but not rpm related, more of an underload issue. thread is here
http://www.clublexus.com/forums/ls40...ng-nuts-5.html
shoob is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
How many miles can I expect out of a Lexus RX300? REN300 RX - First Generation 65 04-30-15 03:54 PM
Tranmission Question CharlieD93 GS - Second Generation 0 04-11-14 07:47 AM
1993 Lexus can I use any ecu with cali emissions? viperrgh2 LS400 3 01-15-14 08:29 PM
93 pulls when cold out - normally cuts out open throttle OKSTANCE LS400 2 01-09-13 10:20 AM
random problems with my ls400 93 nagasakki LS400 37 01-24-05 06:01 PM
Tags
2000rpm, 400, 93, 93ls, 98, bad, cuts, ecu, filter, fuel, lexus, ls, ls400, pump, put, replace, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
