Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
Show me your HID beam pattern
Thread Tools Search this Thread Display Modes
Old 09-04-11, 01:38 PM   #31
01LEXPL
Trader Score: (10)
01LEXPL's Avatar
There's a reason DDM tuning has 30$ HID kits... expecting a full range of colors would be retarded at the 30$ price point
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
01LEXPL is offline   Reply With Quote
Old 09-04-11, 02:30 PM   #32
BAUSauto
Info@BAUSauto.com
Trader Score: (0)
https://www.facebook.com/BAUSAuto BAUSauto
Send a message via AIM to BAUSauto
Its always end up to "you get what you pay for" LOL...
BAUSauto is offline   Reply With Quote
Old 09-05-11, 02:00 AM   #33
fatcat2
Trader Score: (0)
ffaattccaatt2
Quote:
Originally Posted by RA40 View Post
fatcat2 and ray316
Can you snap the beam pattern on the road also? Want to see the throw-pattern 50+ feet out from the car.
cant anymore, cars gone
would of done it for you though. see what i get next and maybe i can do it for you in a few weeks.
fatcat2 is offline   Reply With Quote
Old 10-08-11, 07:49 PM   #34
tenchu
Trader Score: (0)
Already posted a road pattern, heres parked
8k HIDs, Eagle Eye housings one side high beam doesn't work (****ty company ><) and the drivers side is aimed lower than the passenger (to avoid blinding oncoming traffic). For reference this is about a 3ft high cinder block wall
~20ft low beams
Click the image to open in full size.
~20ft high beams
~50ft low beams
tenchu is offline   Reply With Quote
Old 04-24-12, 12:21 PM   #35
timmy0tool
Trader Score: (5)
timmy0tool's Avatar
Send a message via AIM to timmy0tool
took some pics of my pattern, which i am frankly not really thrilled about.
setup:
- 97 stock headlight housings
- DDM tuning 55w 6000k H4 (single mode, no high beam option) HID kit
i already had to replace the first set of bulbs since one color shifted prematurely. i am very careful installing them, they admitted fault and replaced them under warranty. the previous bulbs had a more distinct cutoff but the new bulbs have a difference in shield design (crappier) hence the glare you see below.
low beam only
high beam only, since i have a single H4 kit, the low beam HID bulb turns off and the separate halogen high beam turns on. usually the high beam filament on the H4 turns on in addition to the separate high beam.
against the wall at 20ft (sorry my camera focused on the windshield instead). you can see there is actually a left flare which results in glare to on-coming traffic! i get flashed every now and then usually at dark roads when there is only me and the other car in passing.
again, with a different ISO setting.
results: due to improper bulb shielding the light is scattered to on-coming traffic. also since i am running a 55w kit (vs the normal 35w kit) i get more lumens to the road however at times i feel it's too bright (gasp!) but yes it actually strains my eyes more than i would like. if you are always driving dark roads, it's a good kit but around city driving where light and traffic abound, it may be overkill.
__________________
lateral Gangsta
timmy0tool is online now   Reply With Quote
Old 04-24-12, 11:32 PM   #36
PureDrifter
BahHumBug
Trader Score: (10)
PureDrifter's Avatar
PureDrifter
Send a message via AIM to PureDrifter
switch to 4300 or 5000k and you'll get less eye fatigue.
__________________
1. Black on Black 1999 LS400 PM-spec
-Maya-Megan-Magnaflow-LSportline-Xenondepot-PPE Engineering-Duce-Platinum VIP-Figs Engineering-R1Concepts-
2. Black 2001 MR2 Spyder -#muchroadster-
3. Black 2004 IS300 -Manaray-HKS-Eibach-Kumho-
4. Ebony Teal 1995 LS400 11-8-06
PureDrifter is offline   Reply With Quote
Old 05-03-12, 06:53 AM   #37
Dubbayoo
Trader Score: (0)
I'm still not sure what else I need to convert a '92 LS400. I currently have waiting Eagle Eyes and PHILIPS 4300K D2S HID XENON BULBS. How do I select correct ballasts and conversion kit?
Dubbayoo is offline   Reply With Quote
Old 05-03-12, 03:01 PM   #38
EXE.UCF10
VIP|EXEstyle セルシオ
Trader Score: (2)
EXE.UCF10's Avatar
You have the wrong bulbs Dubbayoo, unless you're planning to do a projector retrofit in your headlights. Your '92 uses 9004 bulbs and the Eagle Eyes use H4 bulbs. What you need is an H4 HID kit, which will require some wire splicing or changing of your stock harness to H4 plugs...or a 9004 HID kit with H4 HID bulbs.
__________________
Original image courtesy of spinout180
Special thanks to:
'Master P' Garage
Song's Tint Masters
TM Engineering
Essential Lites
EXE.UCF10 is offline   Reply With Quote
Old 05-06-12, 12:51 PM   #39
Kalaries
Trader Score: (0)
Kalaries's Avatar
KY YELL
I like to have my Auxiliary lamps Hid, and my headlights stock.
I am a little police paranoid so sometimes I like to be able to turn off my HIDs and blend in.
I had to break out the yellow glass inside the auxiliary lamp because the yellow glass mixed with 6000k hid bulb made the lamps green.
Kalaries is offline   Reply With Quote
Old 05-06-12, 05:00 PM   #40
PureDrifter
BahHumBug
Trader Score: (10)
PureDrifter
uhh except foglights don't have nearly the spread or throw that headlights do....
__________________
Old 05-07-12, 01:33 PM   #41
Dubbayoo
Trader Score: (0)
does the 92 use a single bulb for high and low? is that what bi xenon refers to?
Old 05-07-12, 01:53 PM   #42
Kalaries
Trader Score: (0)
Kalaries's Avatar
KY YELL
Quote:
Yes the 92 used 1 bulb
Old 05-07-12, 03:28 PM   #43
XenonDepot
ClubLexus HID Kit Sponsor
Trader Score: (9)
XenonDepot's Avatar
KBcarstuff XenonDepot
Let me know if you have any more questions Dubbayoo =) I definitely recommend going with 4300k as well.
Steve
__________________
ClubLexus SUPER SALE is on now!! - SAVE $$$
AUTHORIZED LEXUS Parts & Accessories VENDOR SINCE 2004 - SHOP WITH CONFIDENCE
XenonDepot is offline   Reply With Quote
Old 05-15-12, 09:17 AM   #44
Dubbayoo
Trader Score: (0)
Okay, lets try this again. Can anyone go to this link and tell me what to select for a '92 LS400 and Eagle Eyes?
http://www.kbcarstuff.com/Xtreme-Dig...s-p/xt-hid.htm
Old 05-15-12, 11:08 AM   #45
XenonDepot
Trader Score: (9)
XenonDepot's Avatar
If your headlights use a 9004 bulb then you would need to select the 9004 fitment if you want a low beam only kit. If you want a bi-xenon kit then you would need to order a 9004-hl kit.
Steve
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why are the high beams just halogen? konradsa RX - Third Generation 56 10-08-13 08:37 AM
'06 DRL's: Super Lame 5LtrEater IS - Second Generation 5 05-28-13 07:58 PM
Halogen beam Pattern!! harshybar GS - Second Generation 10 08-20-12 07:35 AM
Aftermarket HID Kit Owners OutGolfn IS - Second Generation 14 09-25-10 04:07 AM
2001 ES300 XenonDepot H3 4300K Foglight Kit and randoms vassey50 Lighting 4 03-04-09 01:21 PM
Tags
beam, cut, dark, eagle, eye, fog, hid, is350, lamp, lexus, light, pattern, patterns, proper, shots, show, spots
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
