Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
91 LS400 Wont go past 4,000RPM
Thread Tools Search this Thread Display Modes
Old 04-28-11, 09:21 AM   #1
Hilux22RE
Trader Score: (0)
Hilux22RE
Default 91 LS400 Wont go past 4,000RPM
Hello fellow LS400 Owners!
I Have a 1991 LS400 and i noticed something odd...
I Rarely get on the Gas seeing as Gas prices are 4.69 a Gal
But today i stepped on the gas hard and my LS will not go past 4,000 RPM...
If anyone has had the same problem can you please help??
greatly appreciated.. i will post a Vid up in a few...
http://www.youtube.com/watch?v=d2gyzlU54vc <---- Link to my RPM Fault..
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Hilux22RE is offline   Reply With Quote
Old 04-28-11, 09:34 AM   #2
LiCelsior
Liberty VIP
Trader Score: (30)
LiCelsior's Avatar
LiCelsior
tune up time?
__________________
RIP Liz 7/18/09 RIP Brendan 10/7/11
Like the LibertyVIP facebook page, http://www.facebook.com/pages/Libert...48632848491351
LiCelsior is offline   Reply With Quote
Old 04-28-11, 09:37 AM   #3
Hilux22RE
Trader Score: (0)
Hilux22RE
I Just Changed:
Motor Oil
Oil Filter
Spark Plugs
Wires
Distributor Caps
Ignition Rotors
Fuel Filter
Transmission Fluid
Transmission Filter
I Hope its not the transmission...
Old 04-28-11, 11:12 AM   #4
deanshark
Trader Score: (0)
How does the car run otherwise? Does it idle normal? (600 RPM) It looks like the RPM started at 300. At the begining it does sound that it has a skip or the fuel/air mixture isn't right.
deanshark is offline   Reply With Quote
Old 04-28-11, 11:37 AM   #5
Hilux22RE
Trader Score: (0)
Hilux22RE
It Idles under 600..
But it runs Fantastic!
No shaking or Sputtering it is smooth.
Old 04-28-11, 01:42 PM   #6
PureDrifter
BahHumBug
Trader Score: (10)
PureDrifter's Avatar
PureDrifter
Send a message via AIM to PureDrifter
check dist rotors, ignitors, coils, and the TPS.
__________________
1. Black on Black 1999 LS400 PM-spec
-Maya-Megan-Magnaflow-LSportline-Xenondepot-PPE Engineering-Duce-Platinum VIP-Figs Engineering-R1Concepts-
2. Black 2001 MR2 Spyder -#muchroadster-
3. Black 2004 IS300 -Manaray-HKS-Eibach-Kumho-
4. Ebony Teal 1995 LS400 11-8-06
PureDrifter is offline   Reply With Quote
Old 04-28-11, 03:00 PM   #7
Hilux22RE
Trader Score: (0)
Hilux22RE
Should i change Both Primary and Secondary TPS??
Old 04-28-11, 11:32 PM   #8
Imperium11
Trader Score: (0)
I dont think theres anything wrong with the car
im assuming the ect was not in power mode
and since it sounds like your a generally relaxed driver the ect has learned your style
if you want it to be able to rev fully, reprogram your ect
Quote:
Originally Posted by Lexkost View Post
Now to the ECT reprogram, It is very simple and to be done on freeway ramps...Turn off AC, car must be in 3rd gear ( out of overdive) and turn on ECT make sure that light is on the dash.
From dead start floor it and keep it floored until it runs throught all three gears, and do this about the 6 times , it can be done in a few days and you should notice that the RPM's should start to raise on shifts.........after awhile the trans will shift well into the red line ( only when in ETC mode ) but in regular mode the car will shift much better than before.
__________________
92 LS400, stock till i get a job
Imperium11 is offline   Reply With Quote
Old 04-29-11, 10:59 AM   #9
Hilux22RE
Trader Score: (0)
Hilux22RE
I am going to try that today and follow through to tomorrow and hope it fixes it!
Thanks!
Old 05-05-11, 11:38 PM   #10
Imperium11
Trader Score: (0)
Any Luck on this?
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
1993 Lexus can I use any ecu with cali emissions? viperrgh2 LS400 3 01-15-14 09:29 PM
Rpm KaNsAsKing GS - Second Generation 9 07-01-12 09:24 AM
Reving wont go past 4,000 RPM iceman1117 IS - Second Generation 22 06-30-07 04:19 PM
enginer won't go over 4000 rpm UltraLexx LS400 17 01-25-05 09:15 PM
How hard do you guys drive your LS? LOTC LS400 13 06-29-01 12:32 AM
Tags
1991, 2000, 400, 4000, 450, es300, fast, gs, lexus, light, ls, ls400, overdive, past, rev, rpm, shift, wont
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
