UFC20 interior electronics questions.
Old 05-15-11, 06:42 PM
LSproject
LSproject's Avatar
Default UFC20 interior electronics questions.
Hi I recently purchased a 2nd gen ls400, and I ran into a few problems.
1. The climate and audio control display screens are "burned" and can only be seen at a certain angle / lighting.
2. The power lock only works for the driver side door, though it seems that all other passenger doors' locks seem to nudge a bit, but doesn't fully unlock/lock. Front passenger switch would still lock/unlock driver side, but doesn't do anything to the other doors.
So could the switch motor in individual doors be bad? or could it be a loose wires not making enough contact? If the motor is indeed bad, could a 1st gen motor replace the second gen?
The reason i'm asking was that there is a 1st gen for sale that was wrecked from the front for $400, so I'm just wondering if there would be anything else that's interchangeable between the 1st gen and 2nd gen. Thanks in advance.
Old 05-15-11, 09:21 PM
RA40
Super Moderator
RA40's Avatar
Welcome to CL.
Could be a burnt out bulb that isn't giving you the backlighting. That entails pulling the cluster out though.
As for the door lock actuators, easiest is to hit up your local Lexus/Toyota parts guy to cross reference compatibility.
Old 05-16-11, 08:41 AM
etex
etex's Avatar
The year model of your car is not shown, but do you have a lockout switch on the driver's door control panel?
Old 05-16-11, 11:36 AM
steve2006
steve2006's Avatar
If you can remove the unit (tutorial available) and solder you can buy a new LCD to replace the blacked out one.
http://shop.ebay.com/i.html?_from=R4...All-Categories
Door lock motors are interchangeable (tutorial available).
Old 05-16-11, 12:23 PM
LSproject
LSproject's Avatar
Sorry it is a 1995 model. And yes I do have all the switches for both driver and passenger door.
And steve, thanks alot for the link. If possible could i get a link for the power lock switch tutorial? Thanks in advance.
gmeardi
International
08-04-22 06:12 AM
Zipit555
ES - 5th Gen (2007-2012)
04-16-18 01:54 PM
Wald GS
GS - 1st Gen (1993-1997)
12-25-07 11:11 PM
Wald GS
08-09-04 11:50 PM
Quick Reply: UFC20 interior electronics questions.
