transmission gasket
Old 03-18-11, 02:23 PM
chicov8
chicov8's Avatar
Default transmission gasket
anybody had ever a problem with leaking cork transmission gasket?
i just bought transmission filter and gasket made by wix but my mechanic told me that gasket gona leak
lu400x (09-11-22)
Old 03-18-11, 08:36 PM
gemigniani
gemigniani's Avatar
shouldn't leak, but remember the oil pan bolts are not supposed to be torqued very much - just slightly snug.
Old 03-19-11, 06:57 AM
SRV1
SRV1's Avatar
I think Toyota uses RTV instead of a gasket. I looked on Sewell's site and the diagram does not list a pan gasket which means they use RTV.
James
Old 03-19-11, 11:55 AM
chicov8
chicov8's Avatar
i know that lexus use some kind of silicone to seal pan, but some people used gaskets after they changed trans filter
that gasket i got with filter is aftermarket i bought it at o'riles auto parts and its made by wix
Old 03-19-11, 01:10 PM
johnnyg66
johnnyg66's Avatar
Used a fel-pro gasket was not cork. always fun to get all those bolts going and not misalign the gasket.
Old 03-19-11, 01:35 PM
chicov8
chicov8's Avatar
where you bought your gasket? i ordered another gasket from nappa
Old 03-19-11, 03:46 PM
SRV1
SRV1's Avatar
Do not use a gasket!!! It will most likely leak! Use a high quality RTV and be done with it!
James
Old 03-19-11, 03:59 PM
chicov8
chicov8's Avatar
how many hours needs rtv before you fill transmission with fluid?
Old 03-19-11, 04:08 PM
chicov8
chicov8's Avatar
http://www.lexls.com/tutorials/trans...anschange.html
Old 03-19-11, 06:53 PM
randal
randal's Avatar
I used a gasket from Autozone and it worked fine. I dislike RTV because it is messy and there is a slight chance of getting a piece of it inside the pan(when dried) if not careful.
The main reason for the RTV is that if the pan sealing edge gets bent, even slightly, the gasket is going to leak. Many warp the pan when removing by prying on an edge trying to get the old RTV unstuck. The new RTV can be gooped on which allows for a lot of slop and precise molding to the pan. So, if you suspect a bent or warped pan, use the RTV.
Old 03-19-11, 07:01 PM
randal
randal's Avatar
You want to finger tighten the bolts evenly (use a criss-cross tightening pattern, side-to-side to ensure even pressure). Wait one hour (use recommendation on the RTV package) to allow the RTV to begin to setup(cure). Then snug the bolts down with a torque wrench and add transmission fluid.
Old 03-19-11, 07:20 PM
chicov8
chicov8's Avatar
autozone in chicago told me they dont have trans gasket for 2000 Ls
Old 02-25-24, 11:08 PM
joshuaho96
3rd Gear
joshuaho96's Avatar
I know this is a major thread bump but in case anybody else does this job after finding this thread at the top of Google you should know Toyota FIPG and most other OEM FIPG should be torqued to spec immediately. In fact the 1282B FIPG specified for cooling systems with Toyota SLLC says you only have 3 minutes from the second it leaves the tube to assemble and torque it to spec. Failure to adhere to this means you have to do it all over again. It's also recommended to clean the surfaces extremely well. Any oil will keep the RTV from sticking and cause leaks. Once everything is set correctly wait a full 24 hours before filling with fluid. Almost no mechanic bothers with the last part but if you're doing it yourself you can afford to wait.
Old 02-26-24, 05:18 AM
pucks18
pucks18's Avatar
Let me know how it goes id like to do the same. Toyotas never use traditional gaskets they always use fipg even for their water pumps lol. I’ve heard of people have good luck with regular gaskets. It looks like such a pain in the *** to clean and prep the surface of an oil pan perfectly for fipg, it just constantly gets more oil/fluid on it
Old 02-26-24, 05:19 AM
pucks18
pucks18's Avatar
Just use a inch lb torque wrench for the bolts
dbui
RX - 1st Gen (1999-2003)
09-10-12 08:32 AM
g4ebguy90
Performance & Maintenance
04-09-12 08:12 PM
Gunnut
11-11-11 06:10 AM
Sup2jzgte
04-03-10 09:09 PM
Sweet95LS
03-07-09 12:45 PM
Quick Reply: transmission gasket
