4th gear problem
4th gear problem
So lastnight I noticed that my car will not shift into 4th gear like I had over drive off. I to have a code for the speed sensor but that has been on for months. I can not figure out what it is.
I have sen checked the sensor with a lab scope and it all checks out good. Can you guys please help me out.
One last thing I have a bad exhaust leak would that have anything to do with my problem?
Pull the transmission codes to see if anything flags up as it could be any number of things like shift solenoids,transmission fluid temperature sender unit,wiring fault.
I take it the fluid level is correct and in good condition?
pulled the code and its #42 for the speed sensor. I have had this code for months now and no problems other than speedo not working some times. fluid looked good but decided i would do a drain and change the fluid and filter.
mbsxk8
02-28-16 03:40 PM
