Thinking about buying an LS
Old 03-16-11, 10:45 PM
1STLXS
1STLXS's Avatar
Default Thinking about buying an LS
Hello guys, I'm from the 3rd gen section but have recently got the bug to purchase an older LS to fix up as a show car. I have been looking at the 98-00 body style. I have found a couple but just wanted some input from you guys on which year I should lean towards, mileage, any major issues or concerns I should look for or ask about. I'm looking to spend between 6k - 9.5k. Currently I have found a couple with 140+ miles but looking to spend on the lower end of my price range only because I am going to do some major upgrades (air, audio system etc....) Your input is helpful.
Thanks.
Old 03-16-11, 11:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
maint. records for any LS, but especially for a 98-00 are key. most things you will be able to find by searching which as a 3 year vet you should already be familiar with
here are a couple key points for a 98-00 LS400:
-Timing belt/water pump are every 90k miles (IMPORTANT since this is an interference motor)
-make sure trans has toyota t-iv fluid or equivalent
-no major clunks from the suspension, though some are ok (ie-front strut rods are a simple fix, but ~80-200usd)
-Upper ball joints f+r are NOT cheap to fix
-tilt/telescope on steering column had TSBs, make sure both fxns work.
-make sure the fronts have the nice big 4pot calipers (yes, i have seen them swapped with 1piston calipers from the old LS)
-no ABS/VSC lights on dash
-dash works right (no lighting issues, overly sticky needles)
-door lock actuators work (power door locks, cheap but annoying to fix)
-driver's side door handle sometimes cracks
there's more but it's been covered. the 98-00 is mostly dependable, and since you're going to replace a lot anyways i went past the well known stuff.
Old 03-17-11, 12:25 AM
1STLXS
1STLXS's Avatar
Thanks PureDrifter, Definitely know that search is my friend and appreciate some of the items you listed to look for. Like I mentioned I currently have my eye on two LS one local and the other in CA and want to make the right decision.
Old 08-30-19, 05:30 PM
vassiton
vassiton's Avatar
Definitely go for the gen 2.5 (aka series IV) '99-'00. Newer capacitors. More available parts. Best engineering before the 430 which, I agree, doesn't look as good.
Old 08-30-19, 06:21 PM
JohnAndic
JohnAndic's Avatar
If its a show car then try to get a 1990 or 1991. The 98-00 is the better daily of them all. I'm pretty new though. But if I was you I would shoot for a fully loaded older one.
Old 08-30-19, 07:28 PM
oldskewel
oldskewel's Avatar
And OP, if you can still hear us back there in 2011, forget about the Lexus; instead buy Tesla stock and as many air cooled Porsches as you can find.
bradland (08-30-19)
Old 08-30-19, 09:40 PM
Sin1UZFE
Sin1UZFE's Avatar
Can't go wrong with any year really. Personally I'd like a 92 or 94
Old 08-30-19, 10:26 PM
bradland
bradland's Avatar
Oldskewel is the only one who noticed, not just 1 but 3 ppl responding to an 8.5 year old thread...
Old 08-31-19, 07:55 PM
vassiton
vassiton's Avatar
This is a reference forum. It's timeless. Someone will read this years from now as well.
Old 08-31-19, 08:08 PM
Sin1UZFE
Sin1UZFE's Avatar
Agreed, opening old threads is much better than creating new ones
Old 09-01-19, 04:39 PM
deanshark
deanshark's Avatar
First thing I thought.
Correct. But to a point. There's gotta be hundreds of these threads asking what to look for and what's better if ya search so giving an answer to an 8 yr old question that has already been answered 8 yrs ago doesn't seem right. At this point it starts to be an opinion thread on who likes what yr LS.
Just pointing out something I've noticed alot lately.
Old 09-02-19, 02:39 PM
peterls
peterls's Avatar
Ha ha, oldskewel you gave me a good chuckle !
Old 09-05-19, 02:18 PM
Stereorob
Stereorob's Avatar
theres alot less of them now then there was in 2011.
Old 09-05-19, 03:14 PM
Sin1UZFE
Sin1UZFE's Avatar
In relative running shape anyway.
Old 09-06-19, 05:07 PM
sdls
sdls's Avatar
Nah I think Bitcoin then to now would have been a better investment. But as they say, if me auntie had a pair of bollocks, she’d be me uncle!
Quick Reply: Thinking about buying an LS
