intermitten chirping... how long does idler, bearings last?
If thats what is you better replace it very soon. Depending on the year of the car you could very well have an interferance engine. If thats the case and the bearing goes out look for a $2K job to repair it.
Glad to know it's all good now, The LS400 seems to be making a funny chirp noise and sounds like a rattly diesel engine. I'm betting it's the Serpentine Tensioner that's making all the noise and would like to replace it. Do you have to remove the top timing belt cover to get it out?
Cheers.
Cheers.
Cheers.
Cheers.
Part numbers
Thanks for that information mate, Would you happen to know any part numbers for Gates, Hayden, Dayco etc? It's actually for a '89 Celsior but should be the same as a 90-94 LS400. Pretty sure the toyo/lexus part number is 16620 50020
Oh yeah and did they change over to a newer style of tensioner or fix the fitment issue with some aftermarket serp tensioner's not fitting with the timing belt cover?
Thanks again.
Thanks again.
The McMaster site has all the dimensions you would need, for example
http://www.mcmaster.com/#5972k44/=c93qqb
http://www.mcmaster.com/#5972k86/=c93rvh
Just look up the same size bearing and make sure its sealed on both sides.
I'm thinking about tackling the timing belt, water pump replacement on my LX 470. I'm not a pro but I am not an amateur either. I have all the tools. Bad idea?
Provided you have the confidence,the correct tools,the factory manual.work methodically and have all the required parts it's do able if you take your time and double check everything as you go.
mooseboy84
10-31-15 11:35 PM
