car slightly steers loose on freeway... what could it be?
Old 03-09-11, 08:59 PM
wcoastls
wcoastls's Avatar
Default car slightly steers loose on freeway... what could it be?
still a very newbie navigating my way thru this great site and hope to get pointers from experts.
today on freeway around 65mph or so, i felt the car (what seemed like right front wheel) moved slightly to left and then back to straight like it something was loose... it was definitely a wtf moment. what could cause this?
i searched on wheel bearing, front strut rod bushings, upper control arm bushings. (lower control arm bushings were replaced before purchase of the car)
will be getting new mounts in soon to discuss with mechanic, but wanted to know if anyone had similar experience.
Old 03-10-11, 12:52 AM
RA40
Super Moderator
RA40's Avatar
Check the rack & pinion bushings as well.
Old 03-10-11, 03:30 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
if it only did it once it was probably just an irregularity in the road....
Old 03-10-11, 08:00 AM
acidfire52
acidfire52's Avatar
My car was very loose on the freeway after redoing my suspension. But all the time. Was my upper control arms, they were shot. My car has 252K miles.
Old 03-10-11, 08:32 AM
wcoastls
wcoastls's Avatar
felt it more than once. it was more like wobbling sensation. gonna have to check all suspension pieces... tie rod ends prices not too shabby. but upper control arms, pretty pricey.
Old 03-10-11, 09:02 AM
LiCelsior
Retired
LiCelsior's Avatar
alignment might be off.
Old 03-10-11, 10:49 AM
MicahBerry
MicahBerry's Avatar
For a quick check of tie rod ends, jack the front of the car up so that the front wheels are off the ground. Grab the wheel at the 3 o'clock and 9 o'clock positions and tug back and forth, as if you were trying to turn the steering. Granted, if you're strong enough, you will turn the wheels, but there should be no play ("looseness") in the wheel.
Old 03-10-11, 11:25 AM
RA40
Super Moderator
RA40's Avatar
A worn steering rack bushing will take more steering input to make the turn then as you come out, it will take an over correction to track straight.
waza8i78
02-08-21 02:55 PM
OMAHA
10-30-18 10:13 AM
tedsterb
Suspension and Brakes
02-02-16 10:31 PM
JAB
RX - 1st Gen (1999-2003)
11-07-08 10:53 AM
akxx
04-06-07 11:39 AM
Quick Reply: car slightly steers loose on freeway... what could it be?
