speedometer not working
Old 03-02-11, 10:36 AM
nickels626
nickels626's Avatar
Default speedometer not working
my speedometer is not working and im not sure what to check first, can anyone please help me out on this one? Also has this happened to anyone's ls400 yet?
Old 03-02-11, 11:57 AM
steve2006
steve2006's Avatar
The speedometer gets its information from the sensor on the transmission,I would check this and the wiring to it before doing anything else.
Old 03-04-11, 05:15 AM
HKSC430
HKSC430's Avatar
Did you try giving it a thump on the dash?
It worked for me.
When thumping it doesn't work anymore, you can try replacing the instrument cluster (with a used one).
That also worked for me.
Old 03-04-11, 09:39 AM
InvaderJim
InvaderJim's Avatar
Has the trip and odometer stopped working as well? If so I'm having the same problem.
Old 03-04-11, 12:51 PM
ghenley
ghenley's Avatar
I was able to use the thumping solution for months, but eventually had to replace the speedometer. I think this is a common problem and there are threads here that show you how to fix the problem yourself.
Greg
Old 03-04-11, 01:37 PM
nickels626
nickels626's Avatar
i did try thumping it but to no avail and my trip and odometer still work though, its weird though it started working again, its intermittent but it seems to stop working wen the moisture in the air is high so do u think that there is maybe moisture in the connection or a small nick in a wire im not sure and i thing im going to jack it up and trace the wires back to their sources soon just to check for possibility's.
Old 03-04-11, 04:09 PM
denverdog
denverdog's Avatar
you'd have to give the cluster a hell of a thump to affect the sensor on the tranny!
Old 03-04-11, 05:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
not when the problem isnt always on the tranny...
simple way to check if it is the trans sensor or the cluster is to see if you still rack up miles (on a 95+ car with a digital odo)
Old 03-05-11, 02:37 AM
python
python's Avatar
if its the speed sensor it will effect the shifting and converter engagements
Old 03-05-11, 08:00 PM
nickels626
nickels626's Avatar
Default oh yea
oh yea in what way?
Old 03-06-11, 04:56 AM
python
python's Avatar
www.google.com
its amazing,try it, its free
Old 03-06-11, 01:31 PM
S-Lex-95
S-Lex-95's Avatar
Had this problem with the 95 LS400. Banging on top of dash helped some. my mechanic said we should replace the speedometer with a rebuilt one. OK so $600 later, it still happens once in a while. Thank goodness not too often and if it does, I get on the highway and hit the dash hard a few times. So far that has worked. If I had the skill to remove the unit, I would have tried the fix from this forum, where folks inserted a pin into speedometer face to hold needle slightly above the zero point. The idea evidently is that the needle falls down just a tiny bit too low, and holding it up where it should be fixes problem. Anyway that is what the guys who tried it say. I am just dealing with this rebuilt one. and the bad thing is that it is the car my wife drives every day so when it fails, I hear about it right away.
Old 03-06-11, 05:25 PM
deanshark
deanshark's Avatar
Yea the wife is always gonna NAG about something. (I love being divorced ) Banging on it will only work a couple times but that only makes it worse in the long run. (banging everything loose) $600 seems like a lot especially if it still happens, man would I put up a fight on that one. You can get one from the JY for $50 and change it in less then an hour.
Old 03-07-11, 07:53 AM
nickels626
nickels626's Avatar
How many speedometer sensors are there on the car other than the main one on the transmission?
Old 03-12-11, 09:43 PM
JP-LS400
JP-LS400's Avatar
i have the same problem, turns out the speedometer itself is bad and needs to be replaced. Since you are in Florida give this place a call.
http://www.***************.com/lex.htm
zwentworth (01-23-20)
Quick Reply: speedometer not working
