Help have this hesitation on the gas pedal
Old 02-23-11, 06:57 AM
gm991
gm991's Avatar
Default Help have this hesitation on the gas pedal
So I noticed this the other day, when I step on the gas the pedal seems to stick a little before it goes down, like something is sticking in the linkage, making it harder for a smooth start from a stop.
I'm I explaining this right?
thanks
Old 02-23-11, 02:37 PM
Imperium11
Imperium11's Avatar
check for codes, then search, then search some more
alternatively your throttle body could be gummed up and sticky, but searching is best
Old 02-23-11, 07:17 PM
deanshark
deanshark's Avatar
Did you ever change your valve cover that was cracked? If so maybe you bent something on the throttle body or the throttle cable might be getting caught up on something if it wasn't put back right. Check your floor mat, it could be folded up under the gas pedal.
Old 02-24-11, 06:14 AM
gm991
gm991's Avatar
yes got that fixed thanks, I lube the linkage in the car and it seems to make it a little better.
metalrocke
03-08-11 01:30 PM
Dueces
12-01-10 10:18 AM
Luxor
SC- 1st Gen (1992-2000)
14
11-11-10 12:36 PM
IonFeright
Performance & Maintenance
03-31-09 01:19 PM
eddybell98
RX - 1st Gen (1999-2003)
12
10-16-07 07:25 AM
Quick Reply: Help have this hesitation on the gas pedal
