UCF20 Engine cover on a UCF10?
Old 05-23-11, 06:32 PM
johnnyg66
johnnyg66's Avatar
11254-50010 BRACKET, V-BANK COVE
[LS400 | 1995 | USA] 1 5.47 5.47
Best if you order something else too because the shipping was $12 bucks. Least make worth the while. I havent received the shipping info on it yet so i hope they have it available. Said they did and of the times i have ordered stuff from them its been available.
Old 05-24-11, 03:20 AM
Rollaboy
Rollaboy's Avatar
Ok thank you.
I will order it with the next order i place. I just bought alot of stuff from sewellparts a week ago. But no problem, it can wait.
Old 05-26-11, 10:24 AM
johnnyg66
johnnyg66's Avatar
Originally Posted by vioswhite
before ....
I just test fitted mine and it seems high on the drivers side. Did you have to adjust something on that side to make it drop down lower for a closer fit? Also did you use a different size bolt for the front on the ignition coil?
Thanks
Old 05-27-11, 07:03 AM
MOswagga
MOswagga's Avatar
My cover is even across the engine, but I did notice it made contact with the insulation under the hood of my 91. I then decided to remove the insulation because it was scuffing the paint I put on the cover.
Old 05-27-11, 07:31 AM
johnnyg66
johnnyg66's Avatar
Mo.
Mine seems to be the egr valve keeping it too high on that side. Was you able to use the bolt in front for the coil pack? I ordered two back bolts and the bracket but wont be here till next thursday. I think it looks good in silver.
Old 05-28-11, 07:13 AM
MOswagga
MOswagga's Avatar
Originally Posted by johnnyg66
Mo.
Thanks I was thinking silver gives it a nice lil pop when you open the hood instead of the standard dirty black.
I did an emmisions removal on my LS and completely removed my EGR but I used spacers to line the bracket back up. I know the 96 I pulled from had a different outter egr but the inner part that bolts closest to the engine looks to be the same and shouldn't cause any problem.
I didnt run into a problem where I did have to adjust the ign coil bracket a little to get that bolt to line up by pushing it upward at the point nearest the front of the car. I do have about a 1/4 inch gap between the bracket and the the cover but it can barely be noticed.
Old 05-28-11, 08:30 AM
johnnyg66
johnnyg66's Avatar
Ok, thanks i didnt see a photo of the motor without the cover on it. I figured that the egr had to be adjusted or removed. Doubt i will do that i may have to alter the cover in that area.
Old 05-31-11, 12:14 PM
steve2006
steve2006's Avatar
Just fitted one to mine,I removed the Trac Cover and top spark plug wire cover (doesn't fit without doing this?) then fitted the bracket to the EGR blanking plate (no EGR on this one as a JDM import).
Moved the studs around and fitted the cover.
Old 05-31-11, 07:57 PM
MOswagga
MOswagga's Avatar
cleannnnnnnnnnnnn
Old 05-31-11, 08:03 PM
vioswhite
vioswhite's Avatar
very kute and clean
Old 06-02-11, 04:48 PM
johnnyg66
johnnyg66's Avatar
Bracket and nuts and bolts came in today. Did a test fit. The EGR just makes it alittle high on that side. But overall okay. Anyways you never see the cover all the time. Might cut out the area where the egr sits. maybe.
juvi22003
04-10-14 11:22 AM
jbl-1985
09-09-11 08:51 PM
SC3coupe
07-10-10 02:46 AM
Rash
09-17-07 01:04 PM
kietlander
Performance & Maintenance
04-29-06 12:21 PM
Quick Reply: UCF20 Engine cover on a UCF10?
