how to flush your radiater
Old 02-10-11, 11:43 AM
LS400BOY
LS400BOY's Avatar
Default how to flush your radiater
never done a fush to lex before what are the steps, any help thanks much
Old 02-10-11, 12:18 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
really need to search mate....
http://www.lexls.com/tutorials/cooling/
Old 02-10-11, 12:24 PM
LS400BOY
LS400BOY's Avatar
thats why i got you guys lol thanks homie
Old 02-10-11, 12:29 PM
LS400BOY
LS400BOY's Avatar
so you cant use the green coolant???????
Old 02-10-11, 01:07 PM
syntax
syntax's Avatar
Sure you can. You can also use straight tap water. It just isn't recommended
Old 02-10-11, 01:11 PM
dashan
dashan's Avatar
It is not recommended to use tap water in a cold area since the water could get frozen. LOL
Old 02-10-11, 02:04 PM
LS400BOY
LS400BOY's Avatar
what would happen if i use thr green coolant
Old 02-10-11, 03:30 PM
Raddison
Raddison's Avatar
The terrorists win.
No, really though, the only things I know about the two is that they're different chemically, they both protect against corrosion, its bad to mix them, and the orange is longer lasting.
Old 02-10-11, 04:04 PM
willhickey
willhickey's Avatar
i got green in my sc, dexcool in our ls... call me crazy but i flushed both and i got the coolant from work for FREE.
Old 02-10-11, 04:05 PM
willhickey
willhickey's Avatar
never overheats
Old 02-10-11, 06:09 PM
LS400BOY
LS400BOY's Avatar
Some guy at the shop told me its just a color no differeance??? But really would it hurt the car if i used green coolant on a lexus??????????????????????
Old 02-10-11, 07:13 PM
RA40
Super Moderator
RA40's Avatar
If you are going to do a drain, might as well swap the thermostat at the same time.
The Toyota engineers would say their formula provides the necessary properties to maintain proper function of the various components. I've seen the reservoirs of enough Toyota's filled with all kids of different coolants. My Celica has had Prestone, Valvoline, Dex Cool and when I do this next round, I'll use Toyota. For the LS, it is just as easy to buy a jug from Toyota and know this is the Toyota recommendation.
Old 02-10-11, 07:15 PM
PureDrifter
BahHumBug
guy at the shop is an idiot, the green and red and etc. colors are generally very different in addititves and base compositions. should NEVER mix them, and some are suited for iron/alum/plastic heads/intake.
Old 02-10-11, 07:47 PM
LS400BOY
LS400BOY's Avatar
I think ima just go to the dealer and let them flush it and fill with proper coolant lol got to get my oil change anyways, plus im still tired from replacing the alt and plugging the acv, still aint get all the air out my ps pump
Old 02-11-11, 06:30 PM
LS400BOY
LS400BOY's Avatar
Will it damage the motor??
Quick Reply: how to flush your radiater
