vsc and abs after suspension
Old 02-04-11, 04:30 PM
samurai469
samurai469's Avatar
Default vsc and abs after suspension
did a dumb dumb mistake, managed to pull or cut the vsc wire while doing my coil change.
now the question,
bought obd tester from autozone but did not work
how would i go about finding out which side i messed up? or do i have to manually strip the wire off both right and left to find the wire damage?
any help to reduce my time under the car is appreciated.
thanks.
Old 02-05-11, 05:44 PM
samurai469
samurai469's Avatar
update,
got a ohm meter tested right and left, found the side with no reading.
then another dumb dumb, stripped the entire length of the wire found no damage untill i got to the bottom right by the sensor
should have started there.
sensor read perfect.
soldered and repaired wire
no more problems, headlight leveling, abs, vsc off, check vsc light went off 30 seconds after driving.
taught me not to run 255-40-19 in the front with tanabe spring drop.
lol
Luciefer
Suspension and Brakes
06-27-16 01:39 PM
fastegg
11-18-13 11:11 PM
SmthgWickd
07-05-13 10:30 AM
peewhy
04-12-10 02:28 AM
Mv350
09-18-09 09:56 AM
Quick Reply: vsc and abs after suspension
