fitment ?
02-14-11, 06:47 AM
fitment ?
can i 90 ls400 fit 18x10 rims in the front.
ive search and found nothing on this matter plus i need to know be for i buy.
02-14-11, 06:53 AM
should be aight with mid-high 20s offset.
02-14-11, 09:04 AM
^ +1. Make sure to run stretched tires,negative camber and roll your fenders for more clearance to avoid rubbing.
02-14-11, 09:57 AM
offset is 41. so will that be a problem?
02-14-11, 11:43 AM
Not at all, 41mm is definitely in the mid-high 20mm offset range.
02-14-11, 12:32 PM
Retired
still gonna need to roll ur fenders most likely.
02-14-11, 06:01 PM
Quote:
Originally Posted by
I'mStock
lol.
i'd be worried about inner clearance w/ +41. not 100% that it will be an issue but it seems likely,
02-14-11, 08:38 PM
well thats the issue i was more worried about.
cause i see a ton of 18x9 front 18x10 rear. i figured that they just wanted a stagger fitments not the fact of inner clearance
02-15-11, 12:34 AM
ef9racer
Well after a certain point if one chooses to run higher offset wheels in front to compensate for the 10" wide wheel poking out too much there could be clearance issues, which I believe is why people go towards the 9's or 9.5's up front. It is all personal preference though.
What rims are you getting btw?
02-15-11, 12:08 PM
but i did find out they do come in a 18x9 so now im happy.
so thanks for all the help guys.
Reason: forgot some things
02-15-11, 03:03 PM
Retired
bah those wont look good on the LS...
02-15-11, 03:28 PM
LiCelsior
I second this - they almost look like truck wheels. Putting Shelby wheels on an LS just seems like you're depriving the car of what it deserves.
I mean, it's your car - you'll do what you want with it though. Just my $0.02.
02-15-11, 03:40 PM
how about these
02-15-11, 04:17 PM
im just wheel shopping but i dont have a baller budget my wife is only giving me a 450 cap.
02-15-11, 06:17 PM
for 450 don't bother. i haven't seen even the hottest of the hot deals in that range. maybe ls430 18s, but even then you're pushing it.
