Gauge cluster smoked lens, removeable?
Old 01-26-11, 10:07 AM
mrwoolery
mrwoolery's Avatar
Default Gauge cluster smoked lens, removeable?
I have a 1993 LS400 and am looking to fix the gauge cluster. The smoked lens which covers the gauges is cracked and I want to replace it. Is it possible to remove/replace just this lens?
Old 01-26-11, 10:32 AM
deanshark
deanshark's Avatar
Yes it can. The manual shows the disassembly of the whole unit. It says Push down the locking lugs and remove the meter glass from the meter case. It shows 4 screws but Idk if they are in the glass itself or in the case.
(Volume 2 pg. BE 138)
Old 01-26-11, 10:50 AM
mrwoolery
mrwoolery's Avatar
Cool, thank you!
For future reference in case anyone else has the same issue, here are the part numbers I found from Lexuspartsnow.com:
Part number: 83138-50010 (if your '93 LS400 was built prior to 08/1992...check the production date on your door)
Part number: 83138-50070 (if your '93 LS400 was built after 08/1992)
phlorida
09-26-17 01:50 PM
anesthesia
14
04-30-15 05:28 AM
Nick2JZ
10-04-08 08:35 PM
92sc
12-01-03 09:59 AM
Quick Reply: Gauge cluster smoked lens, removeable?
